swap? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2006, 09:37 AM   #1 (permalink)
View streetnasty's Photo Gallery
Japan swap?
Hey its kenny. What new swap should i drop into my 91 tercel? i already have a 5efe from a pesao. i just have a need for more power. whar engine should i put and money is no object.
streetnasty is offline   Reply With Quote
Old 02-23-2006, 10:59 AM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
2JZGT-E
ToyotaTechGeek is offline   Reply With Quote
Old 02-28-2006, 02:53 AM   #3 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Well, you're in VA which isn't too far from my new shop in SC. Come on down and I'll swap a 3SGTE in there for you, best option while still staying somewhat practical (see above post). Probably can do that for you for around 10 Gs, rought estimate.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 02-28-2006, 08:02 AM   #4 (permalink)
View drehtwnftbl's Photo Gallery
even though money is not an option, that is still a rediculous amount...congrats, dude
drehtwnftbl is offline   Reply With Quote
Old 02-28-2006, 05:09 PM   #5 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
-Doc
Is that the 2.0 Celica engine? What would you do for brakes and suspension..........Dam I want one!!!!!
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 02-28-2006, 06:04 PM   #6 (permalink)
3SGT-E is from an Alltrac Celica or MkII MR2 T
Old 02-28-2006, 07:00 PM   #7 (permalink)
N/A bites
Tercel GTS's Avatar
Twin turbo Viper engine with rwd conversion and 6 speed manual trans.
If money is no object why are you in a Tercel?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 02-28-2006, 09:47 PM   #8 (permalink)
i meant to ask you that...i mean if you already have a few cars and you're just looking for variety, i think it would be sweet to tweak the 5efe all the way...now that would be somthin...
Old 03-23-2006, 08:29 AM   #9 (permalink)
ok well i want to do all the work myself or majority of the work. i want a celica engine mostly and im still in a tercel because most are slow and im a sleeper. just seeing the look on someones face in a delsole or integra when i beat them makes my nigghts. how much would a 3sgte and five speed transmission cost me?
Old 03-23-2006, 10:50 AM   #10 (permalink)
View jijiandfarmgang's Photo Gallery
One Million Dollars
jijiandfarmgang is offline   Reply With Quote
Old 03-24-2006, 01:40 AM   #11 (permalink)
View kaaasap's Photo Gallery
if you really want something exotic and unexpected think outside toyota. think twin turbo vg30 trans mounted from 300zx or twin turbo 6g72 from 3000gt. i know it would cause more weight, but they give the 6 cyl torque and the possibility for awd with the pachage. i know a guy running around tampa who swapped in a 6g72tt into his gen 2 evo. i think his dyno showed over 500 horses in a car weighing less than 3000 lbs. 6 to 1 power ratio is better than the new z06 vette. its 505 vs 3152, but its not awd. and the new vette ran the second fastest lap at nerburg in germany. passing ferarris and lambos, only the twin turbo porsche has a faster time and its only by the tenths.
kaaasap is offline   Reply With Quote
Old 03-24-2006, 04:01 AM   #12 (permalink)
ssl
View ssl's Photo Gallery
id just get a 4e head and get a big @$$ turbo....custom fuel raisl, highflow pump, bigger injectors, and so on.....mostly the big @$$ turbo
ssl is offline   Reply With Quote
Old 03-24-2006, 10:29 PM   #13 (permalink)
i recomend buying corky bells book maximum boost. it will give you a bunch of ideas for turbo sizing and the best ideas about what type of performance you might be looking for. you can buy it just about any book store. some times the biggest turbo isnt the best. then you have to consider the intercooler and how much space you have to cool the air to the lowest ambient temp. to maximize your boost. tercels are kind of tight under the hood and can only hold what the maximum size intercooler for what your applications. remember, torque is what makes speed, not horse power. hp is just how has you can turn that torque. no matter how high your red line is, the torque curve will drop off at 5500 rpms. this is just a constant in gas engines. if you want a ton of torque, look into a desiel engine and stretched out gears. a four speed built to handle massive torque would prolong the time you are getting this outragious torque to the wheels. turbo the hell out of the desiel of course.
Old 03-25-2006, 10:28 PM   #14 (permalink)
I would for sure go with the Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine
Old 03-27-2006, 03:42 PM   #15 (permalink)
Yea well i just want a celica engine? to start with cause i love them and im stayin toyota. i have mr2 seats in it and i dont wanna put a turbo on right away i wanna give it sometime before i do. but i heard that celica engines are very sensitive to mods is that true cause i dont wanna mess up and get blown up and waist all my time and money on a car.
4age 20v vs b18 swap good_old_geo Archived Corolla threads 15 08-28-2006 07:37 PM
3EE to 5EFE engine swap DaBomb77 Tercel, Paseo, Starlet, and Sera Forum 2 08-20-2005 10:51 AM
1992 Toyota MR2 Swap eMcEeNeSs MR2 Forum 7 07-26-2004 10:20 AM
4agze w/auto swap ? SuperV Archived Corolla threads 0 02-13-2004 01:29 PM
ATTN: speedemn - Yoshio Engine Swap Ratko Camry & Solara Lounge 4 12-28-2001 04:22 PM
