I picked up another EP82 rear axle because the SCCA said I couldn't use oversized rotors in my class. Bought one for a seriously low price, but when I showed up to get it I found out why. Worst one I've seen yet other than bent ones.
Here's a picture of a EP82 caliper next to an AE92 caliper.
Popping the cap off to remove the bearings I found more ugliness.
The grease and bearings looked baked. These bearings have been repacked before. All E body cars I've pulled rear bearings from had white grease on outter bearings and black on inners.
Put the nut back on and give it a snatch to pull the seal out with the inner bearing.
Then begin a clean up process.
Betcha you didn't think those rotors could clean up like this.
More to come in a few days..
