rough idling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2006, 10:04 AM   #1 (permalink)
View chrisusvi's Photo Gallery
rough idling
My 92 Tercel, on start up, runs rough for the first 15-20 seconds when I start the car in the morning. It eventually smooths out. It periodically does it when I come to a stop. I have changed the spark plugs and the distributor cap and wires, as well as, the pvc valve.
Is there something that I have missed that would make the the car run smoother all the time?
chrisusvi
chrisusvi is offline   Reply With Quote
Old 02-28-2006, 07:04 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Mine is doing the exact same thing. I'm going to try a fuel filter since I know it has 180,000 and is original. If that doesn't help I have a spare fuel pump to try. I'll tell you if I see any change.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 02-28-2006, 10:56 PM   #3 (permalink)
Cressida nut
Gameroom cash: $251345
View kamesama980's Photo Gallery
small vacuum leak: 95% chance. its a pain to find em, but will cause rough idle, lack of power, bad braking in bad cases. those hoses should be checked and replaced with all others
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 03-01-2006, 08:03 AM   #4 (permalink)
View drehtwnftbl's Photo Gallery
what you can do is spray some smoke-in-a-can into the engine compartment and look for where it moves...it's used for exhaust leaks too
drehtwnftbl is offline   Reply With Quote
NA Smoking and idling rough Piddy MR2 Forum 8 09-03-2005 10:33 PM
98 Corolla hesitation, rough idling, fuel filter?? 98inthe818 Archived Corolla threads 1 04-29-2005 05:22 PM
'92 GTS Idling rough 3SGTE@daSpeedof Celica Forum 3 08-02-2004 02:19 PM
Rav4 2001 Rough Idling xzulu RAV4 Forum 0 05-22-2004 11:04 AM
ECU Error Code 11 car idling Rough Doggy Hardcore Tech and Competition 1 01-23-2003 02:58 AM
