Steps
1, jack up corner and remove wheel
2, turn wheel for easiest access, then remove pin and nut holding balljoint in knuckle
3, remove nuts/bolts holding balljoint to control arm
4, support knuckle, use large punch and huge hammer to smack the top of balljoint driving it down and out of knuckle
5, slip new balljoint back in knuckle and start nut
6, reinstall nuts/bolts that attach balljoint to control arm, tighten
7, tighten nut that holds balljoint to knuckle, insert pin, bend so it cannot come out unless straightened
8, put wheel back on, tighten, put car back on ground
9, test drive, put tools away, wash up
10, roll one and celebrate
雄のハヤブサ
