Hello all.
I thought I saw a postion some time ago that listed and compared the ratios of the Tercel/Paseo gearboxes and that of the 4AG engines. I have used the search feature but come up blank. Could I have been mistaken about seeing it here or am I just not putting in the correct key words.
Does anybody have this information on hand?
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
I found the ratios for the C150 manual transaxle used in the '92 Paseo. I believe they are the same in the Tercel. Somebody correct me if I'm wrong. Anyway I just thought of looking in my repair manual and there it is.
1St - 3.545 : 1
2nd - 1.904 : 1
3rd - 1.310 : 1
4th - 0.969 : 1
5th - 0.815 : 1
Rev - 3.250 : 1
Differential 3.941 : 1
Does anybody have a book on any car with a 4AGE engine, or maybe the 4AFE might be the same. I'd like to compare the ratios.
Here goes... keep in mind that a C## transmission will have the same gear ratios as a C1## transmission... wherever possible, I tell whether a C## and/or C1## was available for that particular ratio set, but that doesn't mean that one can't exist... All C-series transmissions have a 3.250 reverse gear ratio, new generation C55# notwithstanding; they use a 3.214 reverse and 3.944 axle ratio exclusively.
C40/C140
3.545 1.904 1.310 0.969
C50/C150/C50F
3.545 1.904 1.310 0.969 0.815
C51/C151
3.545 1.904 1.233 0.885 0.725
C52
3.166 1.904 1.310 0.969 0.815
C53/C153/C53A
3.545 1.904 1.310 0.969 0.725
C54/C154
3.545 1.904 1.392 1.031 0.864
C155
3.166 1.904 1.310 0.969 0.725
C56/C56M
3.166 1.904 1.392 1.031 0.815
C57
3.166 1.904 1.233 0.969 0.725
C58
3.545 1.904 1.233 0.969 0.725
C59
3.166 1.904 1.310 0.885 0.725
C60/C160
3.166 2.050 1.481 1.166 0.916 0.725
C161 and 162: any help here?
C63
3.166 1.904 1.310 1.031 0.864 0.725
C64
3.166 2.050 1.481 1.166 0.916 0.815
C65/C65M
3.166 1.904 1.392 1.031 0.815 0.725
C66/C66M
3.166 1.904 1.310 0.969 0.815 0.725
C250
3.545 1.904 1.310 1.031 0.815
C251
3.545 1.904 1.392 1.031 0.815
C550/C550A/C550K
3.545 1.913 1.310 0.973 0.804
C551/C551A/C551K
3.545 1.913 1.310 1.027 0.850
Among the available axle ratios of the C-series:
3.526 3.722 3.941 4.058 4.312 4.529
"A" denotes a transmission with fully automated clutch and gearchange, which Toyota calls "Multi-Mode," MMT, or T-Shift5. "M" denotes a sequential manual model (SMT), similar to MMT but without a full automatic mode (all gear changes must be initiated by the driver). "K" denotes a transmission with automatic clutch, but manual gearchange. This is known as "Freetronic".
C250
C251
C550/C550A
C551/C551A
C55# both use a 3.214 reverse ratio and 3.944 axle ratio exclusively
Sweet!!!
Ok, so now I am thinking that the Tercel needs a 1st gear set from a C52 transmission to reduce the gap between 1st and 2nd. That 3.545 is just too low. I wonder if it will swap in?
It'd be nice if we could just pick and choose the gears but from what I understand they are a cluster that doesn't seperate. I have a spare 5 speed from a 93 DX to disect and see what they really do consist of. Just waiting on time/space. I'd like to know if a corolla auto diff will go in a manual. I may have one of those in the test pile soon as well.
I remember reading somewhere, I don't remember if it was here or on Tercel Online, that the 4AGE gearbox innerds would swap into the Tercel/Paseo gearbox and that would be a more evenly spaced set of ratios. If that swap is really possible I think that will be my next project after getting my rear sway bar installed.
