Exhaust Manifold Downpipe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 12:09 PM   #1 (permalink)
94 Tercel
enerjohn's Avatar
View enerjohn's Photo Gallery
Does anyone have a proven method for keeping the nuts on the exhaust downpipe?
Last night I was driving and the damn downpipe fell, and since my O2 sensor is in the downpipe, It snapped the wires to the sensor.
I've tryed lock washers and everything, and this will be the third time replacing the nuts.
Thanx everyone.
enerjohn is offline   Reply With Quote
Old 03-16-2006, 07:04 PM   #2 (permalink)
View jijiandfarmgang's Photo Gallery
hey,
So the bolts are just loosening themselves? Im not sure how yours is setup, but mine came with studs. I did strip the threads though taking them out to change the gasket. Anyways if you wanna keep the nuts on the bolts use lock-tite, either strength will work good on a small bolt, actually I think there is three now.
jijiandfarmgang is offline   Reply With Quote
Old 03-16-2006, 08:55 PM   #3 (permalink)
View drehtwnftbl's Photo Gallery
good call, get the blue stuff...the other thing you could use is teflon tape...i think that's what it is. it's this tape that you put right on the bolt and screw the nut on and it locks and the only way to get it off is to unscrew it hardcore.
drehtwnftbl is offline   Reply With Quote
Old 03-28-2010, 01:06 PM   #4 (permalink)
View don-vee's Photo Gallery
The nuts or studs might be stripped, not to the point of the threads being completely gone, but loose. This happened with my wife's Camry. Toyota used "one use only" nuts on some cars, and once you take them off, there are little barbs that make it very hard to get back on properly without stripping the nut or the stud. I chucked the original nuts and got a pair of grade 5 nuts and lock washers from the hardware store, and hadn't had a propblem since. That was 130,000 miles ago.
don-vee is offline   Reply With Quote
2005 Turbo Exhaust Manifold Flange mr_jiggy_fly79 5th & 6th Generation (2002-2006 & 2007-2011) 5 09-20-2005 09:23 PM
rattle/buzz@2300 = cracked exhaust manifold? dsap100 Celica Forum 2 09-14-2005 12:21 PM
installed tubular manifold and downpipe 91RED3S MR2 Forum 4 08-18-2005 11:59 PM
Corolla exhaust manifold cracks mrb1962 Archived Corolla threads 4 06-20-2005 06:09 AM
Ok to leave exhaust manifold heat shield off? coolchu001 Camry & Solara Lounge 18 04-17-2005 08:52 AM
