Blinker turns on my brights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2006, 09:13 PM   #1 (permalink)
View zips's Photo Gallery
I have a '91 Tercel. When I have my headlights on and then use my blinker to turn left, it almost always turns my brights on also. When I want to actually use my brights, they do not stay on. Does anyone else have this problem? Any suggestions to fix it?
zips is offline   Reply With Quote
Old 03-18-2006, 10:05 PM   #2 (permalink)
ssl
View ssl's Photo Gallery
probly got a problem with the switch or maybe a short in your wiring. see this all the time on sunfires and crapalier's at work
ssl is offline   Reply With Quote
Old 03-18-2006, 10:16 PM   #3 (permalink)
View drehtwnftbl's Photo Gallery
you do know that to have your brights on, you have to push it forward rather than pull it backward and it clicks....right?
drehtwnftbl is offline   Reply With Quote
Old 03-19-2006, 02:23 PM   #4 (permalink)
91 DX
tyler88's Avatar
View tyler88's Photo Gallery
what is teh purpose of the quick flash of the brights?...tell people cops ahead or just to say hi?...sounds pretty useless
Cheap, Fast, Reliable...Pick any two
tyler88 is offline   Reply With Quote
Old 03-20-2006, 06:12 PM   #5 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
Yeah its pretty wierd if you want keep your highbeams on you got to hold the switch back to keep it on pretty useless.
TTercel is offline   Reply With Quote
Old 03-24-2006, 02:18 PM   #6 (permalink)
View layla_proud's Photo Gallery
yeah i have a 92 tercel and it dose the same thing sometimes when i use my blinker. I was told that my switch could be getting worn out.
layla_proud is offline   Reply With Quote
Old 03-24-2006, 03:59 PM   #7 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
The quick flash is a signaling device. It is for the purpose of getting someones attension.
It is used in Europe and other places in the world, on multi lane highways, to signal a slower car in front of you that you would like them to move out of the passing lane so you can pass them. It is also used to signal another driver at an intersection, for instance, that you are yeilding right-of-way for them to procede. It can be used to warn someone who might have not seen you and is planning to pull out in front of you that you are comming. It can also be used to let a friend that you are following know that you have a problem and need to stop. If it is used correctly it can be quite helpful.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 03-24-2006, 07:30 PM   #8 (permalink)
Corsa!
Galvatron's Avatar
View Galvatron's Photo Gallery
It's pretty common for the combination switch to wear out. Mine is beginning to act up a bit as well. Just go pull one from a junkyard or keep an eye on ebay.
1992 Tercel DX, 3E-E/3AT
1992 Paseo, 5E-FE/5MT
2007 Suzuki SV650S
http://www.rent-a-tech.org/wordpress
Galvatron is offline   Reply With Quote
Old 03-25-2006, 11:16 AM   #9 (permalink)
89toyota4x4
View 89toyota4x4's Photo Gallery
my 91 does the same thing. I have learned you can apply a little foward or backward motion as you move the signal to find the sweet spot where it wont flash the highbeams. I suppose someday i should pull a switch from a junker....
89toyota4x4 is offline   Reply With Quote
The blinker switch glitch! Tankedcook Camry & Solara Lounge 3 03-07-2006 10:38 PM
gen4.5 blinker relay question eecc 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-07-2006 04:33 PM
Blinker relay ArknSpark General Discussion 4 12-29-2005 11:11 AM
Blinker is blinking really fast MadDawg Camry & Solara Lounge 5 09-15-2004 06:41 PM
Ratko: Blinker question 88 LE Camry & Solara Lounge 1 09-29-2003 11:44 AM
