Not sure about vacuum hose placement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2006, 06:24 PM   #1 (permalink)
'92 Paseo 205 Black/Grey
Jeff_x's Avatar
View Jeff_x's Photo Gallery
Should the small hose on the left front side of the stock air cleaner box (Gen 1, 5EFE automatic, air), which is plugged into a deadhead adapter (no hole), plug into the front or rear attachment point shown in the following pic
I can't find it in the literature and the only pic I've seen shows the hose (sans adapter) attached at the rear point. Since the adapter IS a deadhead (or plug), it probably doesn't matter--but I'm curious to the point of distraction.
Jeff_x is offline   Reply With Quote
Old 03-21-2006, 03:16 PM   #2 (permalink)
91 DX
tyler88's Avatar
View tyler88's Photo Gallery
on my 3ee its like that too..but i havnt followed the hose to where it goes
Cheap, Fast, Reliable...Pick any two
tyler88 is offline   Reply With Quote
Old 03-22-2006, 11:33 AM   #3 (permalink)
Jeff_x's Avatar
Here is an enhanced(?) vacuum diagram from the technical guide. This is for the 5efe with auto to federal specs.
Still doesn't tell me much about the attachment point for this hose, but it explains the system, which is helpful.
Old 03-30-2006, 10:59 PM   #4 (permalink)
Jeff_x's Avatar
Gen1
The hose connection is the rear fitting on the air filter box's front left side. The front fitting is blocked. Again, this is for the '92 5efe Auto with air. fyi. Per: my mechanic.
vacuum hose diagrams?? instantninja 89-95 Toyota Pickup/Hilux 3 03-14-2006 06:14 AM
which hose is the vacuum hose arclite20 Archived Corolla threads 4 01-16-2006 02:49 AM
22re- Vacuum sensor hose for Fuel Pressure Regulator raucci96 General Discussion 0 05-24-2005 10:46 PM
Sea foam treatment, where is vacuum hose ? KevinLi Camry & Solara Lounge 1 10-13-2004 04:05 PM
