You can use suspention stuff from a 95 - 99. Thats what I did and it works great. I gota set of KYBs off ebay and some cheapo coil overs, all for the 95 - 99 car.
I wasnt able to use the "adjustment sleeves" on the front because they wouldnt clear part of the sturt (i guess thats what i get for being cheap). but since I wanted it all the way down it works out good anyways. On the rear the fit was alot better. The rear springs have to be adjusted about 2" up from the bottom to compensate for the shorter strut, and you will need some kind of washers for the bottom because the bottom of the gen 3 strut is a bit wider where it bould to the "axle".
There was also a member of TO that was using a 91 - 94 front strut bar and said it fit fine, you cna get one from "streetbeat customs" or the right cheap.
HERES THE COMPLETED SUSPENTION
