Head Gaskit Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2006, 03:05 PM   #1 (permalink)
View partimer's Photo Gallery
Head Gaskit Help
I have a 1995 Tercel with a 1.5 DOHC 5e engine. The head gasket went and I replaced it but I can't tighten the head bolts past 45 to 50 ft lbs. I tried finding non-stretch bolt but there are none. The bolts in the engine are 9 mm. No one makes a 9 mm bolt. Help please. Thanks guys
partimer is offline   Reply With Quote
Old 03-23-2006, 03:36 PM   #2 (permalink)
View Daox's Photo Gallery
What do you mean you can't tighten them? Are you using the original bolts or new bolts? Are you using the Toyota specialty tool designed to install and remove the head bolts? Need more information.
Daox is offline   Reply With Quote
Old 03-23-2006, 08:58 PM   #3 (permalink)
View patricklong's Photo Gallery
try using an air-ratchet. u can get one real cheep and there a handy tool if your doing car work!!!
patricklong is offline   Reply With Quote
Old 03-23-2006, 09:01 PM   #4 (permalink)
View drehtwnftbl's Photo Gallery
9mm headbolts?
drehtwnftbl is offline   Reply With Quote
Old 05-31-2006, 10:05 PM   #5 (permalink)
Flagrant Fouler
Diehonda's Avatar
View Diehonda's Photo Gallery
What should the torque be?
Free Gen 2 Camry book for anyone coming through Louisville, KY
Diehonda is offline   Reply With Quote
Old 11-26-2007, 11:33 AM   #6 (permalink)
View jackpot5283's Photo Gallery
XXX
they arent a 9mm they are a 12 point triple box driver available at any parts store for around 2 bux
jackpot5283 is offline   Reply With Quote
Old 11-26-2007, 02:50 PM   #7 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
12 point 8mm. Mac Tools, Snap-On, pretty much everybody has them. You can even order it from Toyota. As for the headbolts, it isn't recommended to re-use them since they do stretch when torqued.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 11-26-2007, 04:25 PM   #8 (permalink)
xkalelx's Avatar
View xkalelx's Photo Gallery
on my 93 paseo with the 5e, the head bolts are 10mm triple box serrated wrench. got the tool at napa. use a small hammer to tap the tool into the head bolts. its a perfect fit.
xkalelx is offline   Reply With Quote
Old 11-26-2007, 06:19 PM   #9 (permalink)
Got a FC3S!
Paseo15psi's Avatar
That actually is not normal. Both my 92 and my 96 have 12 point 8mm according to Toyota specs.
Old 11-26-2007, 08:59 PM   #10 (permalink)
XXX
i too just removed and replaced a 1.5 head today 10mm serrated also says triple box on the package the original and replacement bolts were the same
p.s. what a pain in the ass having to tap it in each time then go back n do again to degree
Old 11-26-2007, 09:23 PM   #11 (permalink)
Got a FC3S!
Paseo15psi's Avatar
Only the 3e equipped Tercel uses 10mm hex to my knowledge, and according to the Toyota Repair Manuals.
Old 11-26-2007, 09:46 PM   #12 (permalink)
Wink
nope the 1.5 i just did is in a 93 paseo with its original motor had the 10mm bolt so were the replacements savage gave me
Old 11-26-2007, 10:02 PM   #13 (permalink)
Got a FC3S!
Paseo15psi's Avatar
That is odd. From my sig you can see that I own a 92 and a 96 Paseo and they both have the 8mm. I have also done engine and head swaps to many 4efte, 5efe, 5efhe, and 5efe DIS and they all had 8mm. I say pull the valve cover and count to see if it is a hex or a bi-hex and then test fit. Heck, I'd lend you mine if you were close. I'm not argueing, just telling you what the manuals used by Toyota say and my experience.
Old 11-27-2007, 11:35 AM   #14 (permalink)
Thumbs up
gotta love car makers i thought gm was the only one that uses 11 different size bolts for the same purpose hah i just bought the whole serrated set at savage a whopping $8 but this yota is done waiting on a crank pulley this one actually pulled off by hand
Old 12-07-2007, 04:10 PM   #15 (permalink)
View rhandwor's Photo Gallery
Go to http://www.matcotools.com/ Click on catalog. Next type in search
toyota head bolt. They offer 3 sizes The 8 bi-hexagonal fits into an 8mm 12 point socket. The 10 bi-hexagonal fits into a 10mm 12 point socket.
The 9 triple square has more pointed tips on the end they are cut different than the bi-hexagonal. They ups within one working days time. Close to Nashville Tenn. They give you 90 to send it back if you don't like it.
If you search amazon the 8 bi-hexagonal is available. Vim tools is one of the cheap ones. CTA Tools also sell them. They offer all three sizes around $15.00 for all three. Otherwise watch ebay. Mac and Snap-on also sell them.
If you are going to do a few buy a good quality tool. My sons Supra used a 10mm allen bolt.
rhandwor is offline   Reply With Quote
5efe head gasket still leaking, I need advice fast !!! reezytercel Tercel, Paseo, Starlet, and Sera Forum 9 05-23-2010 11:26 PM
head gasket replacement tonym509 Supra Forum 7 01-24-2006 07:38 PM
warped head on 22re gluepot Introduce Yourself Here 2 01-04-2006 05:16 PM
