Rough Idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2006, 06:18 AM   #1 (permalink)
View NickR's Photo Gallery
Rough Idle
92 Tercel, manual transmission, 285,000kms.
When first started, on a cold morning, the engine runs roughly (as if on 3 cylinders) for about 10 seconds, and then runs smoothly. Then when the engine warms up, and the idle rpm drops down to about 750rpm, it runs roughly again, with too much vibration. As soon as you press the gas pedal and raise the rpm to about 1,000 or above, it runs smoothly, and has no lack of power.
It has been doing this for a few years. I have changed plugs, wires, disty cap and rotor, pcv, with no improvement. I checked the compression last year, and it was good on all four cylinders.
Does anyone have any clue what might be the cause?
NickR is offline   Reply With Quote
Rough idle cozmo_im 6th Generation (1988-1992) 2 11-05-2008 12:29 AM
99 Tacoma 2.7 rough idle greg 79 f150 1st Generation (1995.5–2004) 8 03-10-2006 04:37 AM
rough idle GuJu MaN 89 Archived Corolla threads 4 12-14-2005 04:14 PM
idle solenoid control motor 96 camry rough starts. help? sigmachibri 3rd & 4th Generation (1992–1996 & 1997–2001) 9 03-25-2004 06:44 AM
