How long has it been sitting wothout running?
I had the same symptoms on my car when I got it. Had a blown head gasket. Sat for two years. Pistons corroded in the cylinders and the engine froze.
If it is a manual shift, (with the ignition off) take out the spark plugs, put the car into 3rd or 4th gear. let off the hand brake and see if you can push the car and turn the engine over. If not it is frozen. Look into the spark plug holes and see if there is coolant in there. There should not be.
Good luck.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
