91 tercel engine work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2006, 09:06 PM   #1 (permalink)
89toyota4x4
View 89toyota4x4's Photo Gallery
I have tried to read other posts to get a general idea of my probelms but i want to make a new one and get some advice.
My daily driver 91 tercel is really a great little car, very economical and fun to drive. However it has been burning oil with the typical blue puff at cold start. It has about 165k miles. Recently i have also noticed blue smoke in the rear view mirror after idling at a traffic light. I have parked the car since it had gotten to the point where i was adding a quart of oil every 350 miles.
I am assuming it is the valve stem seals but plan on doing a compression test to verify. I am willing to spend the time and money to remove & rebuild the head, do timing belt, water & oil pump, etc. There are also oil leaks around the valve cover and what appears to be where the distributor connects to the head. For the record it never uses any coolant and the coolant is not contaiminated whatsoever.
Any advice/tips on these procedures is greatly appreciated. I have a friend who is a mechanic and a garage and plan on doing most of the work myself except sending the head out to be rebuilt. I do have the chiltons manual.
The car is rust free, and the interior is mint which seems to be a pretty rare find in central Ny (the rust belt). I would really love to get some more years of service out of this car.
When i do a compression test (probably in a week or two) i will post the results.
Thanks in advance for your help.
-Chris-
89toyota4x4 is offline   Reply With Quote
Old 04-01-2006, 12:22 PM   #2 (permalink)
View Celler's Photo Gallery
I know exactly what you speak off.
Here what I got from your message. I assume that you have 3EE motor in it. And it is typical for this milage to use up so much oil. And it will only get worse. If you had the car for the while then you might of noticed a slight loss of power and it will be dropping more. About timing belt, if you never changed that do it. (Timing belt has nothing to do with your oil and smoke problem about 50$ to 80$ garage will put it in for you for 350$) but change if you want to keep your engine alive. Moving on. It burns so much oil and smoking so hard because. Your piston rings are fried. And the head gasket is busted.(Head gasket is might not be at fault but ones you are down there change it any ways about 50$ at napa) And your cam shaft cover gasket will run you up about 20$ from Toyota dealership. If you want to rebuild your head go for it, but is not the cause of your smoke but it will improve your power. The main problem are the rings and worn out pistons and bores. Which calls for one thing. If you want to fix it as it is. You can just put new rings in and that's that, but that will only last you so much before it will start smoking again. If you want to go ahead and kill the problem for good there is a lot more involved.
-It pistons are not badly worn keep em` ( if you want to get new ones I am sure it won't do any harm)
-Rings must be new
-You will need to use hone on your bores to make then round again. (If don't know what I am talking about then take your block to a pro let them do it.
To put rings you will need a Ring Compressor it will run you about 80$ or less. Hone will go for about 50$ or less or more ( find some very dialed info on how to hone your block it has to be very precise). Replacement stones for the hone will be about 25$ per set of 3. I never gone as far as removing the pistons I can imagine you will be needing some kind of tool there as well. + the parts. You know what rebuilt 3EE motor will run about 500$ and to fix this out will about 400$ so think about it. I have the same motor as yours right now. It smoking and tripping like hell. That's why I am looking for the new one for the swap. I will never use 3EE again, it is junk. I suggest for your to move on as well .
P.S. To get rind of some or all smoke fast and cheap get it PCV valve it will be about 5$ and takes about 2 minutes to change. Then do a routine tun up
Wires - 60$
Plugs - 20$
Dist cap - 50$ and up
Rotor - 5$
Air filter - 20$ to 30$
Hope that helps. By they way the prices are in Canadian $ Good luck
Celler is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
93 Tercel...Engine Swap? Mystral Hawk Tercel, Paseo, Starlet, and Sera Forum 3 06-19-2005 12:15 AM
Dying Tercel Engine shogun6684 Tercel, Paseo, Starlet, and Sera Forum 13 05-11-2005 01:00 AM
91 Tercel + Engine Swap SnapDragun Hardcore Tech and Competition 2 03-16-2005 08:44 PM
TERCEL 96= can i put a celica gt engine ??? dboss Tercel, Paseo, Starlet, and Sera Forum 4 08-19-2004 06:35 PM
