5efhe mod....
this is something i read in the toyotaowners.com forum
You can also use the 5EFHE with the 4EFTE harness and ECU, the CT9 turbo and manifold from the 4EFTE, with a set of 370CC injectors from a N/A Supra with a AFC for fine tuning. Using a base timing of 5 degrees this combination is very reliable as a daily driver and a blast to drive. This is the combination I am currently running in my Tercel. The other option is to have an exhaust manifold made, use either a Mitsubishi 16G or 20G turbo with either an SDS or Megasquirt stand alone computer system and you can make 190 to 210 at the wheels on 93 Octane using the 440CC injectors from a MR2 driven daily using 15 to 16 PSI of boost. Since not all 93 Octane fuels are the same additional safety may be provided by adding a bottle of 104+ Octane booster. Please note the engine is still internally stock.
