bigger brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2006, 09:34 PM   #1 (permalink)
View Kevpalf's Photo Gallery
2nd Generation bigger brakes
my brakes look really small with my 17's
i'm looking to up grade them unfourtunately power slot has discontinued there rodders
is there any brakes from other toyota models that will bolt on
thanks for any help
Kevpalf is offline   Reply With Quote
Old 04-07-2006, 08:43 AM   #2 (permalink)
TO Refugee
View ShowCarTercel's Photo Gallery
If you have a second gen Paseo (96+) you can upgrade to the first gen Paseo brakes. They are bigger. You'll need the cailer mount and cailper.
Manitoba's First and Only JDM 5efhe Powered Tercel.
It's Running Now!!!
ShowCarTercel is offline   Reply With Quote
Old 04-07-2006, 10:05 PM   #3 (permalink)
My Dixie Wrecked
wedge's Avatar
View wedge's Photo Gallery
Actually you only need the caliper bracket (and the larger rotor of course).
The caliper itself stays the same.
Racing is everything
wedge is offline   Reply With Quote
Old 04-08-2006, 09:47 AM   #4 (permalink)
can you buy the caiper bracket from toyota and if so would you know the part #
thanks
Old 04-08-2006, 10:14 AM   #5 (permalink)
My Dixie Wrecked
wedge's Avatar
It's not a common item to replace, so it would likely be expensive from Toyota.
You should be able to find them easily at a junkyard or find someone who is parting out a car.
You can use a 92-95 Paseo, a 90-91 Corolla GTS, or 87-89 MR2. The front brakes are identical on each of those cars.
Edit: Actually, the front brakes are not 100% identical. The calipers/brackets/pads are identical. But the rotor is different, it has the same overall diameter, but the hub depth is different. You can only use the rotors from a 92-95 Paseo
Old 04-08-2006, 07:06 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
Are you sure the Corolla caliper is identical Wedge? It sure appears to have a much larger piston.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 04-08-2006, 08:34 PM   #7 (permalink)
My Dixie Wrecked
wedge's Avatar
Hmm... that's possible. I never looked at it that close.
I am positive they are interchangable. Even if there are minor differences.
bigger brakes situman Camry & Solara Lounge 13 08-18-2005 10:14 AM
bigger brakes gen3 v6 hoosum 3rd & 4th Generation (1992–1996 & 1997–2001) 7 10-31-2004 11:27 PM
Conversion Kit - Rear Drum Brakes To Disc Brakes Nikolas Archived Corolla threads 5 08-20-2004 10:38 PM
2nd gen V6 brakes bigger than 4cyl? Talisman Camry & Solara Lounge 3 04-25-2004 07:53 AM
bigger brakes???? mtrain Camry & Solara Lounge 12 04-01-2004 01:10 AM
