Originally Posted by donno
If your running a 5efhe, what kind of times are you running? Can you give me some suggestions on parts I may need?
I have never taken my Tercel to a track, plus I'm a lazy whore who kept his 3 speed auto. But if you have a 5 speed and know how to drive. You should be in the 16's with the full 5efhe. I really don't know though.
Parts, do you want to run with the 3ee (91-94 Tercel) electronics (ECU and harness)?
Or do you want to run a full 5efhe setup with it's proper ECU and harness?
If you want to just run with with the 3ee stuff. You will need a distributor from a Paseo the same year as your Tercel. The 5efhe exhaust manifold doesn't line up with the stock Tercel exhaust, so you need to get either an adapter made or a new system.
If you want to run a full 5efhe, then you will either need to make a custom wiring harness yourself. (Lots of work and worry) Or you can order up a pre-made plug and play wiring harness made especially for you from
www.Back-yard-productions.com
