Cooling system - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2006, 12:11 PM   #1 (permalink)
View DebbieSzc's Photo Gallery
Cooling system
I have a 94 Paseo. Water is blowing out of the overflow tank even though the guage does not show that the engine is hot. The radiator was changed and the system holds a pressure. Engine compression is also normal. Any ideas? Thanks in advance! Debbie
DebbieSzc is offline   Reply With Quote
Old 04-22-2006, 04:22 PM   #2 (permalink)
MutantCheese's Avatar
View MutantCheese's Photo Gallery
Your thermostat could be stuck in the closed position. Just my first impression.
Shane's 'Seo Gen I 1992
"Oh what a feeling!"
MutantCheese is offline   Reply With Quote
Old 04-22-2006, 05:29 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
Does it blow water out of the radiator when spinning the engine to start it if the cap is off? If yes then remove the spark plugs and spin it with the plugs out and cap off. If it does not blow the water out with the plugs out, but does with them in you have a bad head gasket/warped head/cracked head/cracked block. If it blows the water out with the plugs out you have a restricted cooling system.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 04-23-2006, 03:26 PM   #4 (permalink)
How do you test for restriction?
Excuse me for being so ignorant but how would you test for a restriction in the cooling system? Thanks so much! Debbie
Old 04-24-2006, 01:39 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Did you do the cap off and the spark plugs out tests? When diagnosing engine troubles you need to do checks in an order or you'll end up guessing and buying parts you don't need.
雄のハヤブサ
Old 04-26-2006, 02:38 PM   #6 (permalink)
Yes, my husband did the tests and the engine appears to be fine. Another thing, it doesn't run hot while driving but when you turn the engine off water boils out of the little overflow tank. Thanks in advance! Debbie
Old 04-28-2006, 04:23 AM   #7 (permalink)
lancekilgore's Avatar
View lancekilgore's Photo Gallery
it sounds like you have a head gasket problem with the compression blowing through the head gasket. another test is to get a radiator tester and put manual pressure on the system. see if it holds or not if not then there is a leak in the head gasket. check the radiator cap?
Lance
lancekilgore is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
V6 Cooling system Beaver Camry & Solara Lounge 9 02-15-2005 08:10 AM
Idea for cooling system wildfire Camry & Solara Lounge 4 02-14-2005 07:13 PM
