Halfshaft Damper - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2006, 03:40 PM   #1 (permalink)
View 91711Paul's Photo Gallery
Halfshaft Damper
Hi all,
My damper on my halfshaft has split and is rattling around on the axle.
I can't find these for sale anywhere on line. no real info on changing it either. I've seen some rebuilt axles that dont look like they even have it.
Do I need to replace it, what if I just leave it as is? The noise really does get annoying,
at first I thought there were empty beer bottles under the passenger seat.
thanks..Paul
91711Paul is offline   Reply With Quote
Old 04-26-2006, 06:36 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
You can use a grinder and cut it off if it annoys you enough. Just don't cut into the shaft.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 04-26-2006, 08:05 PM   #3 (permalink)
But it wont hurt anything to drive it as is, other than my sanity.
Old 04-26-2006, 09:26 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
As long as it doesn't bother the boots nor appear to get jammed anywhere it shouldn't bother anything.
雄のハヤブサ
Old 04-26-2006, 09:48 PM   #5 (permalink)
View Daox's Photo Gallery
I had the same thing happen. I just cut it off like GTS said. A few thousand miles later now and no problems.
Daox is offline   Reply With Quote
Old 04-26-2006, 09:50 PM   #6 (permalink)
Thanks I'll get my die grinder out..lot's of fun cutting stuff.
1992 V-6 Fuel leak - Fuel damper? Montanahelp 3rd & 4th Generation (1992–1996 & 1997–2001) 14 01-17-2006 12:25 PM
Mk1 Mr2 rear damper question 1337haxxor MR2 Forum 0 01-12-2006 01:51 PM
Fuel Pressue Regulator - Pulsation Damper Leaking- Help!! stockrex Camry & Solara Lounge 0 01-05-2006 08:02 PM
Glove Box Damper Tried2Live 2nd Generation (2005+) 8 11-21-2005 11:41 AM
air damper -- how to get to it D0UG Camry & Solara Lounge 1 07-07-2004 12:54 AM
