Unless you really start modifying your engine theres no need to upgrade the distributorless ignition system on your car. If you are going to upgrade you'll have to start out with an MSD DIS-2. You'll have to find some aftermarket ignition coils (or use stock coils) and have it setup similar to the stock setup with the waste spark. I'm sure theres other ways of doing it so you can use the camshaft position sensor to split the signal up and run 4 coil packs, one for each cylinder... I know this is possible with the E-manage Ultimate. But, as previously stated, theres really no need unless you have heavily modified your engine. You won't see great benefits, especially when it comes to bang for your buck (pun intended).
If you are looking for power I'd look at a few other things first. If your looking for a lot of power turbo is the way to go. If your looking just for a bit more pep you can do the regular bolt ons and that'll get you moving a bit more quickly. A few ideas come to mind:
cold air intake
header / performance exhaust
under drive pulley
intake manifold insulator
Aside from the header and exhaust those modifications are fairly cheap, and pretty easy to do yourself. The modifications should net you a small handful of power. Is it enough? Depends on what your looking for.
