HELP!!! my engine stumbles on acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2006, 08:44 PM   #1 (permalink)
Drives 1 loud yota!!!
View steveokinevo's Photo Gallery
can anyone tell me wats goin on here??? it takes usually 2 turns to start the car and when its in neutral its fine but when i put it in drive it stumbles really bad. i've replaced the spark plugs, plug wires, distributer cap, rotar, fuel filter, and still havent solved the problem. anybody have the same experience before??? my very smart diesel technician friend thinks its the fuel pump, wat do you guys think???
steveokinevo is offline   Reply With Quote
Old 05-01-2006, 06:57 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
First I'd run a compression test. If it passes that I'd check fuel pressure then timing.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 05-01-2006, 09:19 AM   #3 (permalink)
well like i said ive replaced like everything but the right thing and it runs better, but the problem still isnt solved. were gonna test the fuel pump, and just to let u know, we already checked the timing and there's no problem there.
Old 05-01-2006, 10:57 AM   #4 (permalink)
88 honda eater
View oreo-650's Photo Gallery
well, if its only when its in gear you should check your tranny fluid... maybe your torque converter is starting to go. you might just need to flush your fluid and change your filter.
oreo-650 is offline   Reply With Quote
Old 05-01-2006, 10:56 PM   #5 (permalink)
my tercel is a standard transmission, LOL
Old 05-01-2006, 11:16 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
I'm sure this is why the assumption was automatic...
雄のハヤブサ
Old 05-01-2006, 11:55 PM   #7 (permalink)
well ive looked through all the troubleshooting and came to a conclusion thats its either the fuel pump is no good or the CAT converter is clogged, sound reasonable?
Old 05-02-2006, 12:25 AM   #8 (permalink)
View ksu_s13Less's Photo Gallery
What are the specs on your setup steveo? Are you running a swap or the stock motor?
ksu_s13Less is offline   Reply With Quote
Old 05-02-2006, 09:06 AM   #9 (permalink)
stock 4-spd 1.5L, WHOOT WHOOT!!! LOL
Old 05-03-2006, 12:20 AM   #10 (permalink)
I'd check the for bad grounds, cracked ignition wires, etc.
Old 05-03-2006, 08:48 AM   #11 (permalink)
View drehtwnftbl's Photo Gallery
if you get an okay flow and no stumbling at higher rpms only, it's your cat. so far, i really doubt that that's what it is.
drehtwnftbl is offline   Reply With Quote
Old 05-03-2006, 04:46 PM   #12 (permalink)
N/A bites
Tercel GTS's Avatar
Have you had the three things I suggested tested?
雄のハヤブサ
Old 05-03-2006, 09:36 PM   #13 (permalink)
havent did a compression test, not sure how, maybe you could explain.( call me stupid if u wanna) tested the fuel pressure, its getting 25 PSI or pounds or watever its measured by( hooked it up to a tester gauge thingy, LOL). checked the timing, the timing is fine
Old 05-03-2006, 11:32 PM   #14 (permalink)
to do a compression test, you can find or purchase a compression gauge that you either screw into one of the spark plug holes or hold up against the hole (i wouldnt suggest the latter)
Old 05-04-2006, 06:54 AM   #15 (permalink)
N/A bites
Tercel GTS's Avatar
^ Do this on each cylinder, if you find a low cylinder then plug an air hose to the adapter to force air into that cylinder. Then listen for leaking air to be escaping through the exhaust pipe, the intake, the crankcase or the radiator. This will tell you where the leak is if one is to be found.
Anytime you or anybody reading this forum has a question about a test please don't feel stupid, just ask. We're glad to explain and at one point none of us knew either.
雄のハヤブサ
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
Engine number four, HELP heroteh Hardcore Tech and Competition 2 05-07-2005 05:07 PM
