4E-FTE and general Turbo questions for the Paseo
I have few questions that I hope can be answered. 1st, if you have a 4E-FTE push boot style distributor (complete) cap, rotor, assembly etc and you have a clip style ignition coil and distributor cap, can you take off the push style distributor cap and replace it with the 4E-FTE clip style distributor cap so it will mate up to the clip style ignition coil and use clip style wires? If not, I may need to invest in a push boot style ep82/4E-FTE ignition coil. The 2nd question is, if your donor car is a paseo with a 5E-FE auto tranny.....if the resources available are not enough, is it possible to take a manual 4efte engine swap, take off the manual tranny and bolt up the 5E-FE auto tranny to the 4E-FTE? If so what parts would be needed to do this? I may need to buy some parts from people who have the ones that may be necessary, so this thread can bring someone some quick business too if it works out! Let me know. Thanks again!
