Knock sensor problem.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2006, 01:33 PM   #1 (permalink)
johndavid345's Avatar
View johndavid345's Photo Gallery
Question Knock sensor problem..
Hi! I checked my engine codes and the code I have is about the knock sensor.. it say that the knock sensor don't have any signal between 1600rpm and 5200rpm. Did somebody know if that can be the problem why i don't have any power and my car is hard on gaz.. And the more important, if somebody know which knock sensor can i use to replace this one..Mr2, collolla, paseo.. thanks for the help..
John
johndavid345 is offline   Reply With Quote
Old 06-13-2006, 08:58 AM   #2 (permalink)
View NickR's Photo Gallery
If the knock sensor is bad, and the ecu detects that it is bad (as it must have done, if you are getting an ecu error code), then I think that the ecu retards the ignition timing, to prevent any risk of knock. A retarded ignition will reduce power and worsen fuel consumption.
I can't help you with the other questions. I don't even know where the Tercel knock sensor is located (I couldn't find any mention in Haynes).
NickR is offline   Reply With Quote
Old 06-13-2006, 12:18 PM   #3 (permalink)
Hi! thank you very much..I'll change my knock sensor tomorrow and wish that was the problem..It would make sense if that was the problem but my car seem to run good on idle and when i don't try to floor it.. And it smell bad when i'm at a stop..doesn't smell when i'm driving.. anyways thanks for the help..
JOhn
Fooling the ECM - sharing 1 good knock sensor for 2 ECM inputs Vibroseis Camry & Solara Lounge 14 10-05-2011 11:39 AM
knock sensor help bowlofturtle Camry & Solara Lounge 6 07-14-2005 12:22 PM
Attenuating Knock signal? JoeB Hardcore Tech and Competition 10 04-17-2005 03:35 PM
homemade knock sensor setup? sleepr Hardcore Tech and Competition 4 11-25-2004 09:38 PM
