Rich on gaz..no power.. need help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2006, 11:59 AM   #1 (permalink)
johndavid345's Avatar
View johndavid345's Photo Gallery
Canada Rich on gaz..no power.. need help!
Hi everybody! Now that's the situation.. I have no more check engine light But my car still rich on gaz and it smell gaz too..and i dont have all the power i'm suppose to have.. the turbo seems to work good if i look at the boost gauge.. so i need your help to figure what can be the problem.. i want all the possibilities and i'll try them one by one... Don't worry! i want everything even if it sound stupid.
-Info on the car..4efte (ep91)new exhaust and catalyc..(is it possible to block a catalyc in 3 weeks if i wasn't burnin my gaz properly?)..
-Spark plugs iridium NGK BCPR6EIX-11
-I order a map sensor separatly from the motor but it say toyota turbo on it and the guy said it was from a starlet..
-I've changed all the gasket and the timing belt..
So please help me!!lol see ya
john
johndavid345 is offline   Reply With Quote
Old 06-17-2006, 01:28 PM   #2 (permalink)
View NickR's Photo Gallery
Check compression (maybe the timing belt went on wrong, so the cam timing is off).
Check for spark on all 4 cylinders (maybe one plug or wire is bad, so unburned gas and low power).
Edit: before you do that, just check you have the plug wires on the disty in the correct order (so easy to get them on wrong) because that would give you unburned gas and low power.
NickR is offline   Reply With Quote
Old 06-17-2006, 07:38 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
Is it rich all the time or just when accellerating?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 06-17-2006, 07:43 PM   #4 (permalink)
It's rich all the time. You see the black smoke coming out of the exhaust on idle..But i rebuilt the motor and the whole exhaust is new.. anything to help me..? any test a can do..
Old 06-17-2006, 07:59 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Hmm, let's start with checking vacuum if you have a means to do so.
I'm not great at diagnosing run problems yet on fuel injected vehicles but I'm thinking you may be able to unplug the injectors one by one while running to make sure each kills a cylinder. If one is leaking it'll probably still fire with it's injector unplugged.
雄のハヤブサ
Old 06-17-2006, 08:01 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
Did it run like this before the rebuild?
雄のハヤブサ
Old 06-18-2006, 08:32 AM   #7 (permalink)
I don't know i buy the motor and rebuilt it right a way..if it's a injector..do you know where can i get one..from a car made in canada..?
Old 06-18-2006, 03:55 PM   #8 (permalink)
N/A bites
Tercel GTS's Avatar
Who made the harness for the car?
雄のハヤブサ
Old 06-18-2006, 11:35 PM   #9 (permalink)
i did the harness.. and i found new information that can help..I've got 150pounds of pressure in cylinders 2 3 and 4 but the first cylinder has trouble getting to 125pounds.. when i'm playing with the connector on the 2nd cylinder it makes a different sound.
And finally my motor oil...I have lot more than full on the dip stick..it smells like gaz and it's liquid and black.. What do you think it can be? head gasket..valve..
I order the gasket kit from ebay but i think it wasn't excactly for my motor.. Do you think a paseo head gasket is the same...? thanks for helping me..really appreciated..
JOhn
Old 06-18-2006, 11:43 PM   #10 (permalink)
N/A bites
Tercel GTS's Avatar
I've seen GT_REVVA say there's a common wiring mistake that makes them dump fuel and even bog out at 4,000 rpm. Does this sound familiar? He also mention fuel washing out the rings and harming the engine so I wouldn't be running it much till sorted.
雄のハヤブサ
Old 06-19-2006, 10:49 AM   #11 (permalink)
well yeah i don't have a tachometer right now but it sound like my problem..do you know what wiring mistake it was.. my Tech just told me that my compression is probably low cause my oil is full of gaz.. so i wont take the motor apart right now..gave me all the info you have about the wiring problem and i will check that.. thanks alot
Old 06-19-2006, 03:06 PM   #12 (permalink)
N/A bites
Tercel GTS's Avatar
I'm not sure right off, but in the DIY stickie I have a link to the diagram I made when making my harness. You may be able to use it to trace yours. Or try calling Trevor at BYP. He's very helpful.
雄のハヤブサ
Old 06-19-2006, 06:49 PM   #13 (permalink)
Oh yeah.. but he will listen to me if i call him and explain my problem..?and is he the type of guy who will try to make money off of me.. What's his number..?
Old 06-19-2006, 09:07 PM   #14 (permalink)
N/A bites
Tercel GTS's Avatar
His number is at the bottom of his page, http://back-yard-productions.com
You can try searching at tercelonline for the answer, I'm sure it's there but buried.
雄のハヤブサ
Old 06-20-2006, 08:15 AM   #15 (permalink)
yeay i always post on both site and i usually have more information on tercel online but now i have more info on this one cause of you.. If you found more info..send it to me..the post will be open as long as i'm not done with the problem.. Thank you
Lexus History BLUEMEANIE General Lexus Discussion 8 11-25-2011 01:53 PM
power steering belt removal and crank pulley Q's CrawlingEye Camry & Solara Lounge 1 06-28-2005 05:51 PM
decrease in power! HELP! kasimmmmm General Discussion 17 04-21-2004 10:20 PM
