breaklight problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2006, 10:21 PM   #1 (permalink)
View littleredrocket's Photo Gallery
breaklight problem
i just bought a 91 tercel so far its a fantastic car aside from the second day i had it i counted 6 piles of birdshit on it and i got a stonechip which has started to crack, dammit!!
i have a problem with my right rear breaklight which stops working only with the headlights turned on. it doesn't look like the bulb is burning out.
has anyone had this problem and have any suggestions on fixing it.
i have yet to check voltage coming from the connections as well as the fuses.
littleredrocket is offline   Reply With Quote
Old 06-19-2006, 05:07 PM   #2 (permalink)
View NickR's Photo Gallery
Welcome to TN!
My daughter's 92 Tercel had EXACTLY the same weird problem. The brake light worked fine when the headlights were off, but wouldn't work with the headlights on.
The solution was to replace the socket for the bulb. Somehow it had become corroded inside, even though it wasn't visible. I got a socket for $5 from a junkyard, cut the wires to the old socket, connected the new one in, and problem solved.
Here's my old thread: http://www.toyotanation.com/forum/t90215.html
NickR is offline   Reply With Quote
Old 06-19-2006, 09:57 PM   #3 (permalink)
i changed a bulb already which deffinitly didn't look like it was burt out, when i did this i sanded the socket due to excesive corrosion on both the socket and bulb.
thanks for the input that sounds like it very well could expain the problem.
Old 06-20-2006, 07:56 AM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Bad connections can make cars do funny things. Welcome to the boards, hang around a bit.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 11:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 02:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 11:27 AM
87 Corolla hesitation problem. Bad_dude Archived Corolla threads 8 10-25-2004 05:31 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 02:33 PM
