instant smoke GALORE= - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2006, 10:01 PM   #1 (permalink)
View jamesmetairie's Photo Gallery
1992 paseo with 145,000 miles. today while i was driving all of a sudden huge amounts of smoke started coming out of the exhaust . this car never did even smoke a little previously. also i heard something sounded like valves clicking,tapping,etc. this car had a few little oil leaks before. a little oil always drips out the bottom of the distributor. last week my shadytree mechanic replaced the crank seal ring. did timing belt a few weeks ago. question = what would make a paseo instantly smoke so much. i thought the car was on fire! thanks for any help you guys can provide.
6&8.
jamesmetairie is offline   Reply With Quote
Old 06-24-2006, 10:49 PM   #2 (permalink)
View NickR's Photo Gallery
Was the smoke white, black, or blue?
NickR is offline   Reply With Quote
Old 06-25-2006, 05:11 PM   #3 (permalink)
smoke galore.
it looked light blue or white. i started it today and it is still smoking even on initial start up cold. the coolant in the resivoir has a light shade of brown. i,m praying it ain,t got a blown head gasket or worst. NOTE = i failed to mention that i dogged the heck out of the car the night before it smoked. it is possible that i got close to the red line. thanks for you response.
6&8.
Old 06-25-2006, 05:22 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Does it seem to be skipping? Pull the plugs out and see if any are oil soaked/bent.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 06-25-2006, 06:31 PM   #5 (permalink)
thanks for the response.what does bent or soaked plugs signify?tell me there,s a small chance that it,s just a small problem. make my day.
6&8.
Old 06-25-2006, 08:56 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
Well if only one is oily it'll at least tell you which cylinder is smoking if not all. You really don't want to see a bent one.
雄のハヤブサ
Old 06-26-2006, 01:24 PM   #7 (permalink)
drunken monkey
View bobthebiker's Photo Gallery
If you saw a brownish color in your coolant, I got bad news for ya. that generally means head gasket go bye bye. check your oil for a color and consistancy of a milkshake. if you've got that, its head pullin time.
bent plug= mega trouble.
bobthebiker is offline   Reply With Quote
Old 06-28-2006, 03:36 PM   #8 (permalink)
View chris90T's Photo Gallery
was the smoke intermittent? did it ever stop? sometimes a failing(but not totally gone)vac booster for the master cylinder will do something like this, but you'll notice the vac. leak in the way the engine runs, unless its a very small pinhole, but either way you'll know soon.
chris90T is offline   Reply With Quote
Smoke under the hood. Help! hokispokis77 Camry & Solara Lounge 13 04-03-2006 06:49 PM
99 Rav Smoke on startup thazallfolks RAV4 Forum 4 11-07-2005 09:09 PM
vaccum line and/or bad spark gap causes smoke ? TdotTercel General Discussion 5 10-26-2005 03:21 PM
Lots of smoke coming from exhaust pipe Scrow Celica Forum 2 08-19-2004 05:58 PM
