I resolved most of the problems I had. But there is 3 I can't fix. So please if you can give me a few ideas.
1. With the swap I put in an Air/Fuel gauge. And that thing shows me crazy stuff. The niddle is never steady . It jumping all over. Doese't matter if I am driving or idelling. It goes all over the gauge all the time. I mean it kind of calms down a little bit when I am driving. But over all the car's Air/Fuel is crap. It shouldn't be like that as I saw it in other cars working.
(A guy on the Tercelonline tald me that the air fuel is some what unstable. But its not THAT unstable. I mean in about 10 seconds or less the niddle on the gauge will jump from lean to rich about 30 times. As I seen it work on other cars; when the car just starts the niddle slowly climbs to optimal and stays there most of the times. The one way it will jump around if there is a hard shifting or agressive driving, even then its pretty stady. So how can make my Air/Fuel to work normal.)
2. After I drive of and come to a stop, a red light. I can hear the engine revving up and down, up and down, up and down. By it self. Firs it does it fast. Then slowly and then just idels.
(And the harder I drive the longer it takes for that thing to go away. If I drive really hard and come to a stop the engine will rev up and down really fast and longer, then slow down more and more and then it just ideals normaly. I talked to a mechanic at work and he said that that thing it called "The engin is Hunting". Not sure about the spelling).
3. My car never came with the Tach in the gauge cluster. So I got the cluster with the Tach in it from the 92 Tercel. I hooked it up, but the tach is the only thing that is not working. Since my car never had Tech in it and never had a Maunual tranny is there some wires I have to change around to make the tach work. Also now as I look at the speedo niddle and go faster it shakes when it moves up. Before it use to go up steady. What I should I chek to make that thing stay calm.
(I think I need do some wire work on that but I can't find the pin out with discription for the plugs that I have. I found one for paseo but it has 3 plugs. I got 2 plugs comming outa of my car that plug on the back of the cluster. Mine is 94, 4 door, no ABS car. I got the gauges fro it from a 92 Tercel the same as mine exept that one has a Tach on it. Also when even I pull the Ebrake, apart from the Ebrake sigan the Low Batt indicator also comes on. it does not comes on for the Low Batt though it comes on for the Ebrake. So what wires should I chanage around to makes that cluster work properly. Do I even have a wire for the tach on my car? If not where should I run it from and to what pin?)
