89 Tercel Tranny Swap? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2006, 06:44 AM   #1 (permalink)
srsimon082104
View srsimon082104's Photo Gallery
I recently purchased a 89 Tercel with 96100 miles for $600. I think I'm third owner. I have org. window sticker ($10,354.99 - sold at Hoover Toyota, Birmingham, AL)
It has a 3-speed auto. I really don't like it.
I would really like to put a 4 or 5 speed manual in it. Is this feasible?
I have to drive 30 miles to get to work - (Georgetown, KY plant) - most on highway and interstate. The poor little 3-speed screams on the interstate (sp. limit is 65 mph, I run at about 70.)
Hope someone can help..
S. R. Simon
srsimon082104 is offline   Reply With Quote
Old 09-19-2006, 07:08 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
You can do it but it's no easy task. Mounting the clutch master cylinder is the worst part in my opinion.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 09-19-2006, 02:27 PM   #3 (permalink)
AstroVannin's Avatar
View AstroVannin's Photo Gallery
I've done it on a Paseo, on a 1989 Tercel it wouldnt be a big deal. Just make sure you have the right hole saw for the clutch cyl...... If you can get a whole donor car that would be for the best so you would have everything you would need. If you have to go to the wreckers make sure you take EVERYTHING, and check that shit twice, so you dont have to go back.
AstroVannin is offline   Reply With Quote
Old 09-19-2006, 04:26 PM   #4 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
if you want to keep it auto my 4e-fte trans is for sale
Saving the best for last
StealthSeo is offline   Reply With Quote
Old 09-19-2006, 04:53 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
How many wires connect to the 4efte trans?
雄のハヤブサ
Old 09-19-2006, 05:40 PM   #6 (permalink)
StealthSeo's Avatar
like sensors? one or two i cant remember
Old 09-20-2006, 02:04 AM   #7 (permalink)
srsimon082104
Is that 4e-fte tranny a 4 or 5 speed? Will it bolt up to the 1.5 Tercel engine and shafts fit? I know (and prefer) that putting another auto in my Tercel would be much eaisier.
thanks
Old 09-20-2006, 10:49 AM   #8 (permalink)
StealthSeo's Avatar
4 speed! and its direct
Old 09-21-2006, 09:34 AM   #9 (permalink)
Good luck getting the torque converter back into the trans, ha ha ha. thats why we wnded up doing the last swap.
Old 09-21-2006, 11:17 AM   #10 (permalink)
StealthSeo's Avatar
once i sell the trans it wont be my problem
Old 09-21-2006, 12:58 PM   #11 (permalink)
N/A bites
Tercel GTS's Avatar
Putting it back in should be no problem, just hold it as centered as you can while spinning it and pushing in. When the parts line up it'll slide in.
雄のハヤブサ
Old 09-21-2006, 01:08 PM   #12 (permalink)
StealthSeo's Avatar
oh alright
Old 09-23-2006, 08:09 AM   #13 (permalink)
Theres 2 little "keyways" that you cant see beacuse of the housing around the input shaft. They're next to impossible to get to line up.
Old 04-21-2010, 11:40 AM   #14 (permalink)
View kidkewl09's Photo Gallery
did the tranny swap bolt right up?? i also have an 89 tecel auto that i want to put a 4speed auto in. i found a transmission from a 92-94 paseo and was wondering if that would be a direct a bolt on or is there another transmission that would be better? thanks
kidkewl09 is offline   Reply With Quote
replacing tranny 86 tercel 4wd,6 speed splick Tercel, Paseo, Starlet, and Sera Forum 4 09-27-2004 07:54 PM
Locating Starlet Parts for Tercel Swap Toyfiat Tercel, Paseo, Starlet, and Sera Forum 2 04-28-2004 07:17 AM
Tercel - Celica Swap ? Flames Tercel, Paseo, Starlet, and Sera Forum 1 03-14-2004 06:53 PM
Need Help. Need Toyota shop to do Tranny swap Talisman General Discussion 2 10-08-2003 09:40 PM
Gen 2 Tranny Swap spills1969 1st & 2nd Generation (1983–1986 & 1987-1991) 2 10-02-2003 09:37 PM
