4efte w/lsd swap axle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2006, 05:33 PM   #1 (permalink)
View willyhaze's Photo Gallery
I blew my engine in my 96 paseo, and decided to swap in a 4efte instead. The swap is almost complete, but the passenger side axle is too big, because The 4efte engine/transmission i got came with lsd. What axle will fit into my car??? I can't find a starlet gt axle anywhere online, and my mechanic said he never even heard of the starlet.
I need help quick, he's gonna take it to get cut and that is crazy expensive. Plus I can't wait to test this new engine out.
Thanks for any help
willyhaze is offline   Reply With Quote
Old 09-19-2006, 05:38 PM   #2 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
You might have to buy from toyota direct.
Saving the best for last
StealthSeo is offline   Reply With Quote
Old 09-19-2006, 06:04 PM   #3 (permalink)
I think my mechanic said they only had 82 starlet parts, the engine was from a 92 starlet
Old 09-19-2006, 06:14 PM   #4 (permalink)
StealthSeo's Avatar
i have cut axels you might have to custom make them
Old 09-19-2006, 09:07 PM   #5 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
www.driveshaftshop.com Not bad prices for custom axles. Or contact one of our members from across the pond.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 09-19-2006, 09:18 PM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
Bolt in a corolla transmission until you get an axle. The tercel axles will work then and the corolla trans should be cheap. Check http://car-part.com for one from a 90-97 5 speed.
By the way, who made the wiring harness?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 09-19-2006, 11:12 PM   #7 (permalink)
Thanks for the replies. I guess my best option is for them to cut the stock axle. But it should be done tomorrow or thursday. After the axle is installed and the stock exhaust customized to fit on the 4efte flange I'll be ready to roll!
TercelGTS - My mechanic made the wiring harness himself from the blown 5efe and the new 4efte.
Old 09-20-2006, 01:22 AM   #8 (permalink)
View thefish's Photo Gallery
I've heard that BYP often has obscure foreign parts like these for sale if you ask them. Sounds like you've got it figured out though, good luck!
thefish is offline   Reply With Quote
Old 09-20-2006, 04:50 PM   #9 (permalink)
N/A bites
Tercel GTS's Avatar
Originally posted by GT_REVVA
......unfortunately, there's no way to say which cars came 5 speed. I do see em in the Junkyard all the time though....from 87-98 Tercs and all year Seos. the going price is $200 + shipping. I currently have one, one 4EFTE tranny and 2 5EFHE trannies with LSD ( though those will require a special passenger side axle....approx. 5 inches shorter than stock.....which I can get upon request)
Contact BYP, do NOT get an axle cut!
Also, check a dr side corolla axle. Should be a touch longer than tercel dr side and a good bit shorter than stock pass side.
雄のハヤブサ
Old 09-30-2006, 10:26 PM   #10 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Originally Posted by Tercel GTS
Bolt in a corolla transmission until you get an axle. The tercel axles will work then and the corolla trans should be cheap. Check for one from a 90-97 5 speed.
The Corolla "A" tranny bolts up to the Tercel/Paseo/Starlet "E" blocks?
If that is the case, a "C52" tranny would solve my first-second power gap!
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 09-30-2006, 11:01 PM   #11 (permalink)
N/A bites
Tercel GTS's Avatar
You have to swap the bellhousings.
雄のハヤブサ
Old 10-01-2006, 07:29 PM   #12 (permalink)
Donald's Avatar
Ohhh!
My Tercel transmission doesn't have a removable bell housing. The shell is just a two-piece unit, split through the differential. So I would have to change the half of the shell that has the bell housing attached? Will it mate up to the other half?
I have read that you can just swap the first-gear-set from the 7A-FE or 4A-GE tranny into the Tercel/Paseo transmission. If I need to split the cases, it probably would be just as well to just do that.
Either way, I understand that shimming and torque/drag checking is involved if you want the tranny to last. I've got tools, but I am not sure I have all that would be needed for that.
( Oooooh!! an excuse to buy more tools Not a bad idea )
need help..3sgte swap problem turbo_GT Celica Forum 9 05-13-2004 12:30 PM
Turn signal problem Chris990 Camry & Solara Lounge 3 04-02-2004 11:06 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
engine swap problem mk1ldragon MR2 Forum 1 11-29-2003 03:55 PM
