Starlet hood swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2006, 06:14 PM   #1 (permalink)
A Brother's Promise
View PaseoJay's Photo Gallery
Gen1 Starlet hood swap
I am awaiting the arrival of a Starlet hood to put on the EL44 Paseo and was wondering about the fitment issues. If you have done the swap, what needs to me modified? What adjustments need to be made? Thanks for any and all info you can give. Take care and always GOD Bless!!
PaseoJay is offline   Reply With Quote
Old 09-24-2006, 12:46 PM   #2 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
I haven't done it, but the Tercel can fit that hood easier than a Paseo. You will have to change the inner and outer fender panels along with the upper radiator support. The front end of the Paseo swoops down way too much. Oh on a side note. Stop bidding against me on those brakes! lol
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 09-25-2006, 12:38 PM   #3 (permalink)
A Brother's Promise
Thanks for the input with the hood and sorry about the bidding situation. I am just trying to get a head start on parts in case I need to replace anything Starlet based.
Old 09-26-2006, 07:09 PM   #4 (permalink)
A Brother's Promise
It does not fit!! It ends up being about 5 inches short from the grill. I will have to Chip Foose it!!!
Old 09-26-2006, 10:21 PM   #5 (permalink)
View tgidavid's Photo Gallery
too bad your not closer to California. I'm trying to make a paseo CF hood with the starlet TMIC duct. Problem is I have a good condition starlet hood to copy the duct but I dont have access to a good condition paseo hood or the measurements on where the TMIC will be positioned on the paseo.
tgidavid is offline   Reply With Quote
Old 09-26-2006, 11:48 PM   #6 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
once i get my 4efte in i will tell you where it needs to go b/c i am going to make a scoop on mine
Saving the best for last
StealthSeo is offline   Reply With Quote
Old 09-27-2006, 12:44 AM   #7 (permalink)
If you want a copy of the scoop, I can make one of those. I'm not sure of the demand of a starlet scoop, but I'm willing to make a few if there is interest.
Old 09-27-2006, 06:07 AM   #8 (permalink)
StealthSeo's Avatar
how you making it?
Old 09-27-2006, 09:37 AM   #9 (permalink)
fiberglass
Old 09-27-2006, 02:56 PM   #10 (permalink)
StealthSeo's Avatar
how much? and what will it look like?
Old 09-27-2006, 07:16 PM   #11 (permalink)
Don't know exactly until I make it. Basically looks like the top scoop part of the starlet. I figure you would need to cut a hole for the scoop to be functional.
Old 09-27-2006, 08:53 PM   #12 (permalink)
StealthSeo's Avatar
well heres the deal, i am pretty sure the TMIC fits under the hood but is right on the hood so heat would be horible there so needs a scoop. well when you get one done tell me how much it would be, i will be needing two
Old 09-27-2006, 09:11 PM   #13 (permalink)
Know anyone else that might be needing one? Cost goes down if I buy materials in bulk. The TMIC is realy close to the hood and yes it does need a scoop. Most people get a fmic but thats extra money that I dont have. I'm going to run to the fiberglass store and pick some supplies. Hopefully I can get something made in about 1 month.
Old 09-27-2006, 10:03 PM   #14 (permalink)
StealthSeo's Avatar
awesome, sounds good
Old 10-01-2006, 06:09 AM   #15 (permalink)
View cynos_turbo's Photo Gallery
Hey all,just joined up here as im running a cynos turbo,just to let you know what i done with my bonnet for the vent is that i cut out a large square in the gt bonnet,make sure you just cut out the top skin of it and cut it right back and include the holes for the window washers as those holes will line up with your own window washer holes perfectly.. the vent will line up perfectly with the top mount intercooler,mark and cut your own bonnett and mould the vent onto your own bonnett,thats what i done with mine and it worked a treat...Will post some pics of my cynos later...cheers
cynos_turbo is offline   Reply With Quote
Hood protector warning... nomad 2nd Generation (2005+) 83 05-16-2006 12:59 PM
4AGE Silver Top swap in a Starlet? josemata16 Tercel, Paseo, Starlet, and Sera Forum 8 03-26-2006 01:44 PM
carbon fiber hood Group Buy Jonsblckhwk Yaris, Vitz and Echo Forum 9 03-01-2005 02:09 PM
5th Gen VIS Carbon Fiber hood added BLAZETIGER Camry & Solara Lounge 17 02-07-2005 01:43 AM
Starlet Front End HeLp... TeRcElIcA Yaris, Vitz and Echo Forum 11 04-27-2004 05:59 PM
