Deckplate Modd - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2006, 03:08 PM   #1 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
Deckplate Modd
Is it ok if I take off the tubing to my air filter box? Take it all off and run it as if I did i deckplate mod? Would it increase any response in the engine or will it stay the same since im sucking in more hot air but being less restrictive? Oh by the way my engine bay isnt this messy I took this picture before i cleaned it up ....
TTercel is offline   Reply With Quote
Old 09-26-2006, 03:24 PM   #2 (permalink)
That Acura Guy
TTercel's Avatar
Anyone?
Old 09-26-2006, 07:38 PM   #3 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
i did that before putting an intake just take off your box and buy a aftermarket filter it will help
Saving the best for last
StealthSeo is offline   Reply With Quote
Old 09-29-2006, 10:42 PM   #4 (permalink)
Banned
4speedsleeper's Avatar
View 4speedsleeper's Photo Gallery
or ypu could go with your stock setup and just replace the element <air filter>in the box with a k&n and get better results than a short ram intake pipe your already at the coldest point with the stock setup straight from the front of the car you cant get anybetter than that unless you cut a hole in the hood and put the filter on the throttle body.
4speedsleeper is offline   Reply With Quote
Old 09-30-2006, 10:45 AM   #5 (permalink)
StealthSeo's Avatar
that works, my friend got some some scrap metal made a quikc box cut a hole in it to the pipe diameter. then lined the inside of it with heat wrap did well you could feel the difference between the inside and the outside of the box
Old 10-12-2006, 09:03 AM   #6 (permalink)
Banned
4th Generation
you should tell you buddy to throw some ice packs in the airbox aswell might be better
Old 10-12-2006, 04:50 PM   #7 (permalink)
StealthSeo's Avatar
acually you know the stuff that that freezes stuff to breaking point? its like cyro but he is going add that soon ice cold!
I need a 2006 stock air intake 2006TacoSupreme 2nd Generation (2005+) 1 11-24-2005 07:11 AM
Changing Air Box Filter AFS_779 Camry & Solara Lounge 10 11-25-2004 12:59 PM
Air filter usage ctrigger Archived Corolla threads 0 10-30-2004 11:49 PM
