Originally Posted by cocheeze
when i look down the mouth of the carb., all i see is a cylindrical plate blocking the opening.
i was told this is the automatic choke, and that it would retract after the car warms up. it does not do so.
casey
Haynes Manual: Page 4-1, Feedback carburetor - The fuel / air mixture is mechanically controled.
That is what that cylindrical thing does, it mechanically controls the fuel mixture. It is not the choke, it is the vacuum slider and responds only to manifold vacuum. It varies the venturi opening in relation to the intake manifold vacuum to keep the fuel mixture correct. That way when you go suddenly to wide open throttle and the butterfly opens all the way up, you do not get a bogging down caused by a lean condition.
It is the best and worst part of those carburetors. When it works, it makes for a very smooth throttle response, but if it gets gummed up, or has a vacuum leak, it becomes the death of the carb.
Haynes manual page 4-13 has an exploded view diagram of the carb. Top right corner of the diagram there is a thing called a compensator, I believe that is the enrichener (choke) mechanism.
What NickR said about that electronic air bleed control valve is correct, it could be your problem or a part of it too.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
