bad oxygen sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2006, 11:37 PM   #1 (permalink)
View algernonsidney's Photo Gallery
bad oxygen sensor?
Can a bad oxygen sensor cause a car to stall? It's a 1995 Toyota Tercel.
It sometimes stalls when decelerating. It's often at a place such as
stopping after exiting an interstate, where it goes from 60 mph to zero.
Someone did a diag and said that the oxygen sensor was bad,
algernonsidney is offline   Reply With Quote
Old 10-07-2006, 10:26 AM   #2 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
change it, its always good to change it every 3 or 4 oil changes
Saving the best for last
StealthSeo is offline   Reply With Quote
Old 10-07-2006, 03:42 PM   #3 (permalink)
Most say change it when it goes bad. One person in another forum says it's the fuel cut circuit. It seems as though it is either getting too much gas or not enough.
I sometimes have to accelerate it to get it to restart.
Old 10-07-2006, 08:26 PM   #4 (permalink)
View toyomoho's Photo Gallery
Get the exact trouble codes and post back.
Old 10-07-2006, 09:10 PM   #5 (permalink)
StealthSeo's Avatar
maybe fuel pump is going bad
Old 10-08-2006, 12:12 AM   #6 (permalink)
PROBLEM SOLVED.
I am embarrassed to report that I had never had the fuel injection cleaned or the fuel filter changed. Performance is much improved now.
Thank you.
Old 10-08-2006, 09:20 AM   #7 (permalink)
Well it stalled again. It did after about six or seven miles of
going 60-70. It stops in situations going from 60 to 20 or less. Even
that is intermittent.
Old 10-09-2006, 01:40 AM   #8 (permalink)
View Dolanite's Photo Gallery
Is your check engine light on?
Dolanite is offline   Reply With Quote
Old 10-09-2006, 06:04 AM   #9 (permalink)
It was on. It isn't anymore. I think the code got cleared.
86 Camry engine warning light 6cyl Renoite 1st & 2nd Generation (1983–1986 & 1987-1991) 3 08-29-2006 09:14 AM
Oxygen Sensor P0135 Code braun Camry & Solara Lounge 7 06-22-2006 09:43 PM
2000 echo oxygen sensor thread size snowshoe Yaris, Vitz and Echo Forum 0 02-28-2006 05:58 PM
Oxygen Sensor celica2004 Archived Corolla threads 3 08-23-2005 06:08 PM
