turbo problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2006, 01:23 AM   #1 (permalink)
View cynos_turbo's Photo Gallery
turbo problem
Hey guys,just wondering if anyone had this problem,when im accelerating and the turbo is spooling up,i can hear a sound like air escaping,i have checked all piping and no leaks,i have a boost controller installed so i removed it but im still getting the same sound,i even removed the bov and still no difference..Any ideas guys..Btw..its a cynos with the 4efte conversion.
With great power...come's great responsibility..
cynos_turbo is offline   Reply With Quote
Old 11-06-2006, 11:26 AM   #2 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $267565
View TTercel's Photo Gallery
Hmmm check your oil and see if your burning any of it...
TTercel is offline   Reply With Quote
Old 11-06-2006, 05:23 PM   #3 (permalink)
I dont mean to sound rude but what would the car buring oil have to do with the sound of leaking air,all toyota's burn a drop of oil
Old 11-07-2006, 06:21 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Pictures of your setup will be most helpful.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 11-16-2006, 11:46 AM   #5 (permalink)
View Maximuscr31's Photo Gallery
How have you checked for leaks? did you pressurize the piping with the car off while reading a pressure guage?
Maximuscr31 is offline   Reply With Quote
Old 11-18-2006, 06:13 PM   #6 (permalink)
Banned
4speedsleeper's Avatar
View 4speedsleeper's Photo Gallery
another way to check for leaks is to get some soapy water and pray in those areas make sure the car is cold before doing this never want to spray cold water on a hot motor.also if you want get some hose and put it to your ear and the other end to areas capable of leaking air to find your problem.
4speedsleeper is offline   Reply With Quote
Old 11-20-2006, 02:27 AM   #7 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
yeah a stealthascope helps alot to howne in on the sound. i am thinking its your exhuast hook up or a bad turbo.
Saving the best for last
StealthSeo is offline   Reply With Quote
Old 11-20-2006, 05:48 AM   #8 (permalink)
This is going to only show vaccume leaks. Leaks that only surface under pressure won't show up. If you want to use soapy water then do it after you have pressurized the entire system to at least 15psi with the car off. If it bleeds off extremely slow then it is fine, if it doesn't then you will hear the air leak and be able to spray the vaccume or coupler leak with soapy water to make 100% sure.
Old 11-20-2006, 05:52 AM   #9 (permalink)
Steathascope won't help you under boost while rolling down the road. Sounds like he has a boost leak somewhere in the piping or vaccume lines. It may not be visible, and it may not even leak till it hits 3, 4, 5 or even more psi. Also just because your boost guage says your hitting full boost doesn't mean you really are. Most turbo setups do not use the turbo nipple to supply the wastegate a vaccume/pressure source. Most source it from the intake manifold or something post turbo. If this is the case the car can have a leak after the turbo and read (intended example) 9psi. In reality the turbo is having to produce (ie) 30psi to push enough air past the leak and enough pressure to still read that. This will kill a turbo and cause excessive heat normally and can lead to predetonation and blown head gasket or possible catastrophic lower engine failure.
Whats it gunna take to Turbocharge my 86? Aniki Archived Corolla threads 35 10-30-2005 10:34 AM
odd vibration problem niju321 Camry & Solara Lounge 3 07-07-2005 12:15 PM
Turn signal problem Chris990 Camry & Solara Lounge 3 04-02-2004 11:06 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
