Paseo Transmission swap complicated? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2006, 09:21 PM   #1 (permalink)
View HgBoy's Photo Gallery
Just curious if it is somewhat feasible to swap a manual tranny into an auto paseo for cheap. I would rather have a manual tranny in any car I drive, but I would need to know exactly what parts to locate, the cheaper the better.
HgBoy is offline   Reply With Quote
Old 11-08-2006, 08:26 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
>Fly wheel.
>Clutch disk and pressure plate.
>Clutch master cylinder, slave cylinder and lines.
>Complete pedal and bracket assembly (clutch, brake and gas).
>Shifter and cables.
>Thermostat housing (clutch slave cylinder might interfere with water hose connection)
>Maybe the brake booster (auto might be larger than manual and interfere with clutch master cylinder).
That's all I can think of. Maybe a few other small items.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 11-08-2006, 09:05 PM   #3 (permalink)
Paseo Beating just beging
View paseobeater's Photo Gallery
you forget the ecu
paseobeater is offline   Reply With Quote
Old 11-09-2006, 04:54 PM   #4 (permalink)
Donald's Avatar
Originally Posted by paseobeater
you forget the ecu
You have a good point. But no, not really, I didn't forget that. I didn't include the ECU because if you swap that then you have to mess with re-pinning the connectors, or swapping the wiring too.
I am using an ECU from an automatic on my manual. My engine was mated to an automatic tranny in the donor car, and I got all the wiring from the same car when I did my engine swap. Car runs great except for < http://www.toyotanation.com/forum/t98509.html >
Old 11-11-2006, 12:11 PM   #5 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
you acually can use an auto ECU, i am for my swap both dr. tweak and trevor said it was alright and would work.
Saving the best for last
StealthSeo is offline   Reply With Quote
92 paseo engine swap t_dot_SiR Tercel, Paseo, Starlet, and Sera Forum 13 12-17-2010 11:48 AM
Tercel Transmission Swap Tercel95 Tercel, Paseo, Starlet, and Sera Forum 4 10-24-2006 05:02 PM
Transmission swap with a 91 Camry?? 89_3SFE Celica Forum 1 07-27-2005 07:29 AM
Transmission swap - manual->auto Dirk Camry & Solara Lounge 23 07-06-2005 03:45 PM
93 Paseo Engine Swap lfdwoodworks Tercel, Paseo, Starlet, and Sera Forum 8 12-27-2004 08:49 AM
