Paseo 92 Won't Start Help ! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2006, 12:26 PM   #1 (permalink)
View mig25's Photo Gallery
Question Paseo 92 Won't Start Help !
Battery is good.
Ground strap is OK
I crank it nothing happens , just a Hissing sound by the right side of the engine.
I could not find a Starter Fuse.
Any suggestions ?
Please help. Thanks
mig25 is offline   Reply With Quote
Old 11-09-2006, 07:53 AM   #2 (permalink)
BLARRGH!!!!
Madcat's Avatar
View Madcat's Photo Gallery
Does it rotate when you turn the key?
Start with the starter and fuel pump relays.
Jim
I have opposable thumbs I WILL prevail.
'92 Paseo - 4E-FTE, Poly engine mounts/full front bushings, Whiteline rear swaybar, 3in exhaust.
Coming soon - Built 5E, ACIS int mani, Starion FMIC.
Madcat is offline   Reply With Quote
Old 11-09-2006, 07:58 AM   #3 (permalink)
Paseo 92 Auto Does Not Start
The ignition key turns normally, lights come on. But Nothing happens other than a Hissing sound under the hood.
I made sure , battery is fully charged.
No Fuses are Blown
Ground Strap is fine.
Please help !
Old 11-09-2006, 02:45 PM   #4 (permalink)
Gameroom cash: $341035
View hikeback9's Photo Gallery
when you turn your key to the start position does your engine turn over?
did you check the relays?
hikeback9 is offline   Reply With Quote
Old 11-09-2006, 02:54 PM   #5 (permalink)
No, Engine does not turn over. Nothing Happens.
I have checked few relays, any particular one I should look ?
I have checked all the fuses on the cabin, driver's and passenger's side, had to remove glove compartment for that.
Also in the engine bay , no fuses or Relays are apparently bad.
Old 11-09-2006, 02:56 PM   #6 (permalink)
TPC
View paseo's Photo Gallery
auto or 5 speed?
paseo is offline   Reply With Quote
Old 11-09-2006, 02:58 PM   #7 (permalink)
how did it run last time?
Old 11-11-2006, 12:08 PM   #8 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
mig, make sure that your sensors are all pluged in properly and vacuum lines are also properly connected. sounds like there isnt a connection between your starter and/or ground. my advice is to take it in to a mechanic and let him figure it out. it will save you the head ache and time. hope this helps.
Aaron
Saving the best for last
StealthSeo is offline   Reply With Quote
Remote Start Help (Viper 160XV) LE05 Audio, Video, and Security - Tech 9 11-09-2006 03:26 PM
90 Tercel coupe 92 Paseo Interior? RANGER4219 Tercel, Paseo, Starlet, and Sera Forum 2 10-21-2006 10:11 AM
'92 Camry NO start Trbomike 3rd & 4th Generation (1992–1996 & 1997–2001) 3 06-18-2006 12:07 AM
92 paseo for sale ztoyota Tercel, Paseo, Starlet, and Sera Forum 2 12-24-2005 12:26 PM
Recaros Start seats are now just $195.95! Buy last years close out fabrics and save! Safe Drives Supporting Vendor Sales 0 11-09-2005 07:17 PM
