EGR Valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2006, 01:39 AM   #1 (permalink)
View paseoman96's Photo Gallery
EGR Valve
I have a 96 toyota paseo 1.5l 5efe motor. I just bought the car from a friend. It has a check engine light and when I went to have the codes checked out it turned out to be a Flow restriction in my EGR Valve. Is there any way that I can blow air threw it, or is there any way I can put a blocking plate on it or will that affect something in the motor???
paseoman96 is offline   Reply With Quote
Old 11-15-2006, 02:42 AM   #2 (permalink)
View toyomoho's Photo Gallery
I think there is a metal tube running to the bottom of the EGR valve that is part of the gas circulating system. This pipe could be plugged up. The valve itself may be clogged and need cleaning, or there could be a problem with the vacuum actuating system/diaphragm valve.
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
EGR valve '96 ES BobES300 General Lexus Discussion 0 11-16-2005 08:44 AM
1990 Camry 3sfe EGR valve Kep 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-29-2005 10:33 AM
egr valve replacement write up TheRyanator Camry & Solara Lounge 2 12-14-2004 09:07 AM
EGR Valve _VVTi_ Camry & Solara Lounge 21 10-11-2004 10:35 AM
