correct air/fuel mixture, MIL code 25 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2006, 10:44 AM   #1 (permalink)
View iruka_hoshi's Photo Gallery
How do you think I should go about fixing a MIL code 25 (Air/Fuel Mixture too lean). WHen I first start my car it'll run at about 2krpm at idle, then slowly sink down. hot idle sits about 800rpm.
I sadly don't have a timing light, so I can't really check the ignition timing. Looks like the idle adjusting screw is left on the thottle body. I am also thinking it could by the O2 sensor, but I didn't get a failure code. Although as I understand the code for the O2 is if there is no signal.
Car someone please clear this up... I tried to google this and what a EBSV is, but I couldn't get any clear answers. From an ealier post someone said a code 25 is cause when the 02 sensor is in open loop or the EBSV is always open.
My Car Doman page
http://www.cardomain.com/ride/2304111
iruka_hoshi is offline   Reply With Quote
Help! 22RE: failed smog & code 25 Reefcrack Pre-88 Toyota Pickup/Hilux 3 01-05-2007 11:02 PM
Air- Fuel mixture Lean Error Code Vibroamp Archived Corolla threads 1 06-22-2006 07:52 PM
OBD-I code 25 Vibroamp Archived Corolla threads 1 06-22-2006 06:24 PM
Plans for AIr/Fuel mixture gauge. MississaugaGTS Archived Corolla threads 1 03-21-2004 01:12 PM
air fuel ratio questions... HPR Archived Corolla threads 12 12-02-2003 07:10 AM
