The only reason a wheel may not ever fit would be because of lug patter or number of lugs, totally wrong offset, bore diamerter for the hub can be too small. For instance. I am running some custom forged wheels on my 98 GSX. They are a 5x 114.3, +27mm offset, 17x9, and 67.1mm hub centric bore for a Eclipse( which is too small for alot of vehicles). I run a 275/40/17 tire all the way around and it has to be extremely far offset so not to use wheel spacers. One other thing is brake clearance. Using the same wheels as example I can run up to a 14" stoptech kit if I wanted to, instead im running 3000gt vr4 calipers and audi s8 brembo rotors. I can not run a stock wheel on my car because the brakes are too big now, at least on the front. Just always try to get wheels that fit the hubs bore also, and if you can't buy hub centric rings to adapt the bore size from what you have to what you need so the wheels will be nice and snug
