Radiator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2006, 04:45 PM   #1 (permalink)
View ndestree's Photo Gallery
Radiator
I have a crack in my radiator and it's towards the top near the cap, so it needs to be replaced should I Just bite the bullet and pay to have it fixed? or should I replace it myself?
Is it hard to replace myself? and if not does anyone have step by step replacment instructions.?
ndestree is offline   Reply With Quote
Old 11-20-2006, 08:35 PM   #2 (permalink)
View Daox's Photo Gallery
Its pretty easy to replace yourself. You just drain it. Remove the intake snorkel. Then disconnect the fan(s) from the wire harness. Then pull off the tubes running to it. Then unbolt it on top and pull it out. Take the fan(s) off and put them on the new radiator and reverse the process. Its very easy. However, I recently took the radiator out of my 93 Terc and the bolts holding the fan on were totally rusted to the nuts on the radiator. I ended up having to cut the mounts off the old rad (theyre only plastic) because of this. Other than that hickup its a piece of cake.
Daox is offline   Reply With Quote
Old 11-21-2006, 02:11 AM   #3 (permalink)
thank for the reply, I just actually looked at it from underneath and it looks like the AC Condesor is out of the way and it should be a piece of cake. I just bought a replacment Radiator for it and I'm going to do it my self. thank for notes, ill use them to help.
Gen 3 I4 Radiator Change/ Thermostat Change RningOnFumes 3rd & 4th Generation (1992–1996 & 1997–2001) 54 10-22-2011 02:35 PM
91 Camry Radiator Question champ_168 1st & 2nd Generation (1983–1986 & 1987-1991) 2 08-15-2005 01:37 AM
Replaced Radiator - what is this wire?! PDXterra Celica Forum 8 08-13-2005 07:43 PM
Gen 3 Radiator install *DIY* Camry_rider 3rd & 4th Generation (1992–1996 & 1997–2001) 0 07-08-2004 01:53 AM
So I'm going to finally replace my radiator...and I need some help- A Bit Urgent! Structureboy Camry & Solara Lounge 10 04-18-2004 12:31 AM
