Need advice-Temp. keeps rising - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2006, 09:59 AM   #1 (permalink)
View ndestree's Photo Gallery
So my Car runs fine. I just instaled a new radiator and all was well and at idol it runs perfect, but when i start driving the temp. starts to rise unless I have the heater on it rises. With the heater on though it stays at half (perfect), thermostat? water pump? I'm not sure anyone else have this problem
ndestree is offline   Reply With Quote
Old 11-30-2006, 11:22 AM   #2 (permalink)
View Daox's Photo Gallery
I'd start with the thermostat. Its cheap and easy to fix.
Daox is offline   Reply With Quote
Old 12-01-2006, 11:11 AM   #3 (permalink)
View NickR's Photo Gallery
Just double-check that the coolant level is full. It's easy to get air in the system when replacing a radiator. If that's OK, then yes, as Daox recommends, replace the thermostat. If that doesn't fix it, try a cooling sytem flush. Only if that fails, look at replacing the water pump.
NickR is offline   Reply With Quote
temp overshoot....overheating, etc. slim_slc 89-95 Toyota Pickup/Hilux 23 12-13-2006 10:19 PM
1989 Toyota Corolla SR5 Temp Guage, Idle, ECU and more retiredat44 Archived Corolla threads 14 03-14-2006 05:43 PM
thermostat temp bmw5002 Archived Corolla threads 4 11-10-2004 08:39 PM
Legal Advice? Rights as a seller. driiift_hachiroku General Discussion 9 07-06-2004 04:35 PM
Need some expert advice I.G. Camry & Solara Lounge 4 12-04-2003 12:11 AM
