tercel diesel manual? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2006, 01:49 PM   #1 (permalink)
View iruka_hoshi's Photo Gallery
Does anyone know where I can get or has a manual for the tercel diesel 91-94 (1n-t)?
My Car Doman page
http://www.cardomain.com/ride/2304111
iruka_hoshi is offline   Reply With Quote
Old 12-01-2006, 03:35 PM   #2 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
that a boy...doing the turbo diesel sorry man i just research the engines i dont know where a manual will be but i wwill look for ya
Saving the best for last
StealthSeo is offline   Reply With Quote
Old 12-02-2006, 03:52 AM   #3 (permalink)
View t_cel_t's Photo Gallery
i doubt anyone in the states has one, i dont even think a 1nt swap has ever been done b4 in the states. make friends with some jap dude that also speaks english and heve him get you one.
t_cel_t is offline   Reply With Quote
Old 12-02-2006, 09:43 AM   #4 (permalink)
StealthSeo's Avatar
they car your looking for is a NL40 corsa, should be a dirrect bolt well fit atleast that was the 90-93 gen which is 91-94 gen in the states
Old 12-04-2006, 03:23 PM   #5 (permalink)
The 1n-t is a mechanical engine, meaning no ECU. The injection is done by mechanical pump jet.
I'm not super familiar with older style mechanical transmissions. So I wonder how timing and what not are accomplished. I also concered as regards to emissions. I've been thinking if this could be converted to electronic control like most modern diesels.
Maybe a mechnical system is better, I mean they did use it for diesels up until 96 or so. After it seems like most diesel where electronically controlled. I really like toyota's d-4d and even ford's diesel. Of course none of those will ever make it state's side.
I hope to be running on SVO primarily though, which standard has all around lower emissions than gasoline engines. Plus it's or was a lot cheaper than gas. SVO in corvallis is usually a good 30-60 cents cheaper at the pump per gallon than gasoline. SVO with hydrogen supplimentation I am thinking would be best. Propane maybe a good supplimentary option too, especially for cold weather.
As we all know diesel relays on heat from compression to ignite fuel versue gasoline with require a spark for ignition.
I figured a manual would be necessary to get a better intimate knowledge of this engine. That is before I completely jump off the deep end and do something crazy. Although I am sure there are more than a few people that think I am crazy for even considering such a thing!
My Car Doman page
Old 12-04-2006, 03:46 PM   #6 (permalink)
Thanks StealthSeo..
Magically I got something I wanted in google.
http://www.alljapanesecars.com/cdsto...a&cdid=to36l40
Seems like a simple program, so it should run just fine in VirtualPC.
My Car Doman page
Old 12-04-2006, 07:18 PM   #7 (permalink)
StealthSeo's Avatar
Awesome looks good man good luck
Old 12-05-2006, 02:12 PM   #8 (permalink)
I Bleed TRD
willtotheumm's Avatar
View willtotheumm's Photo Gallery
wouldnt the manual be in japanese? thus really hard to read?
1988 Supra Turbo- Stock 7M-GTE, 5-speed manual, HKS Turbo timer, ARP headstuds, planning 2jz-gte swap
1988 MR2- Stock 4a-ge, 5-speed manual, planning 20v swap
My Cardomain / My Myspace
willtotheumm is offline   Reply With Quote
Old 12-05-2006, 02:15 PM   #9 (permalink)
StealthSeo's Avatar
its made for the euro's so its in english
Custom Tercel Body Kit TeRcElIcA Tercel, Paseo, Starlet, and Sera Forum 19 12-30-2009 01:49 AM
95+ Tercel Carbon Fiber Hood Group Buy Tercel Drifter Tercel, Paseo, Starlet, and Sera Forum 13 07-21-2006 10:30 AM
Lots of Paseo, Starlet and Tercel Parts FS! Gizmo Tercel, Paseo, Starlet, and Sera Forum 6 06-26-2006 11:17 PM
Looking Into Buying a 95+ Tercel RBoy8 Tercel, Paseo, Starlet, and Sera Forum 1 05-21-2006 03:29 PM
Tercel buying help CamNub Tercel, Paseo, Starlet, and Sera Forum 2 08-26-2004 09:57 PM
