Engine surging in 85 Tercel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-02-2006, 11:47 AM   #1 (permalink)
View Dormandy's Photo Gallery
1985 Tercel hatchback. At about 1500 rpm the engine speed cycles up an down about 150 rpm, with a steady throttle. It is a 3A carb motor with recent electrical tune. I cleaned the EGR valve, new plugs, cap, rotor. Air filter is good, new oil. No obvious vac leaks. Any ideas?
Dormandy is offline   Reply With Quote
Old 12-02-2006, 03:56 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Check to see if the nuts that attach the carb to the manifold, and the ones that attach the manifold to the head are tight.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
20R ENGINE REBUILD FROM HELL! (Part Three) nwdetectorist Pre-88 Toyota Pickup/Hilux 1 08-09-2007 07:30 PM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
1989 Tercel surging...badly Marb750 Tercel, Paseo, Starlet, and Sera Forum 8 12-30-2004 05:02 PM
TERCEL 96= can i put a celica gt engine ??? dboss Tercel, Paseo, Starlet, and Sera Forum 4 08-19-2004 06:35 PM
