Driver Side Door Handle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2006, 02:00 PM   #1 (permalink)
View jlvkfyang's Photo Gallery
Winter is here, and it broke my outside driver side door handle. We had some freezing rain, and when I went to open the door, the handle broke in half. Half of it is still available, and I can open the door with it, but I would like to replace it.
Anyone with DIY instructions that I can follow? Also, any good resources of where I can find the actual handle. Thanks.
1992 Toyota Previa All-Trac
jlvkfyang is offline   Reply With Quote
Old 12-05-2006, 02:17 PM   #2 (permalink)
Banned
4speedsleeper's Avatar
View 4speedsleeper's Photo Gallery
4th Generation ahh yes the door handle
Originally Posted by jlvkfyang
Winter is here, and it broke my driver side door handle. We had some freezing rain, and when I went to open the door, the handle broke in half. Half of it is still available, and I can open the door with it, but I would like to replace it.
It's a pretty easy job just go to a salvage ard or dealer and pick one up. Your going to take the door panel off but you will need a phillips screw driver because, there is a clip you'll need to take off the bottom part of the window arm.then remove the door panel you will see 2 screws or bolts I can't remember exactly pop out broken peice take your lock out incert lock in new peice and finally put it all back together its sound like a lot of work but it takes me about 20 min or so.I done 3 of them on different cars.
4speedsleeper is offline   Reply With Quote
Old 12-05-2006, 03:29 PM   #3 (permalink)
I will take a look at a local junk yard. Are there any other car handles that are compatible with the 96 Paseo, ie. tercel, 1st gen Paseo? Thanks.
Old 12-05-2006, 08:07 PM   #4 (permalink)
Banned
4th Generation
Other than Toyota I'm not sure I wouldn't chance it.
driver side mirror P-Town Camry Camry & Solara Lounge 3 05-31-2006 07:58 AM
ATTN: ek-9 - Driver Side Tail light Takeshi_Nakazato Archived Corolla threads 1 02-22-2003 11:18 AM
