Tranny Oil.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2006, 09:21 PM   #1 (permalink)
View RuTerc's Photo Gallery
Question Tranny Oil..
Hey guys..
Im finishing my 3ee to 5efe swap and im reusing my 4spd manual tranny.
Now, the question is what tranny fluid do i use? i went to the store and asked the guy which oil i use in the tranny and he said to get "ATF DEXRON III Automatic Transmission Fluid" he didnt even ask me if its auto or manual, so without thinking i bought it..
then i come home and thought to myself to check my haynes manual and see what it says because it was strange to use auto tranny fluid in a manual i thought, and for the manual tranny it says to use "API GL-5 75W-90 gear oil" and for auto it says to use "DEXRON II"...
So any of you guys used ATF DEXRON III oil in your manual tranny?.. whatcha think?
RuTerc is offline   Reply With Quote
Old 12-06-2006, 06:28 AM   #2 (permalink)
StealthSeo's Avatar
View StealthSeo's Photo Gallery
umm use whats recomended just to be safe
Saving the best for last
StealthSeo is offline   Reply With Quote
Old 12-06-2006, 10:35 AM   #3 (permalink)
TO.COM Refugee
alfradio's Avatar
View alfradio's Photo Gallery
Agreed!!! By the way, treat that tranny of yours to a couple quarts of Royal Purple gear oil...
you'll be glad you did!
alf
alfradio is offline   Reply With Quote
Old 12-06-2006, 11:29 AM   #4 (permalink)
Talking
Thanks guys.. im going to return that ATF shizzle i bought and get me some Royal Purple goodness like alf suggested
by the way anyone knows how many liters i need to top it out?
Old 12-06-2006, 11:45 AM   #5 (permalink)
TO.COM Refugee
alfradio's Avatar
I think 3 or 4 quarts will do it (or was it 2 or 3???) Pretty sure it was 3 or 4!
alf
Old 12-06-2006, 12:24 PM   #6 (permalink)
View pidster's Photo Gallery
3 will just about fill it. I'd get 4 just to be on the safe side. You'll need more at some point so why not.
pidster is offline   Reply With Quote
Old 04-14-2007, 07:59 PM   #7 (permalink)
View Vikz99's Photo Gallery
so we can only use ATF DEXRON III as an transmission oil? or can we use any transmission oil? cuz i used mr.transmission (canadian...lol) oil..? let me know.
Vikz99 is offline   Reply With Quote
Old 04-16-2007, 09:09 AM   #8 (permalink)
lancekilgore's Avatar
View lancekilgore's Photo Gallery
For a automatic it calls for Dex II or III but you can use a equivilant to DEX like royal purple.
Lance
lancekilgore is offline   Reply With Quote
Old 04-16-2007, 09:58 AM   #9 (permalink)
yeah.. i just checked the label on the mr.transmission bottle and it says good for use for dexron III and II. thanks for your help
Old 04-16-2007, 10:05 AM   #10 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
that trans seems to like a slight bit more than what it takes to 'fill' it. my hard 1st to 2nd shift condition cleaned-up after i filled it with RedLine MTL then i topped with AmsOil 80W90
ToyotaTechGeek is offline   Reply With Quote
Old 04-16-2007, 03:49 PM   #11 (permalink)
Good to know my old truck started haveing shifting problems, New fluid to. look into it.
Lance
Old 04-16-2007, 11:52 PM   #12 (permalink)
View Flip123's Photo Gallery
the tercel 5efe (dis) is 75w-90 gear oil btw... and it only took me 2.5 quarts to fill up my tranny with mobil 1 synthetic gear oil btw, going synthetic made a great improvent in shifting.... its a lot smoother and easier to get into gear in the manual it says the 5efe only needs 2.3 US quarts... so i dunno i got 3 quarts so that should be good enough
1995 Toyota Tercel
Flip123 is offline   Reply With Quote
Old 04-17-2007, 08:31 AM   #13 (permalink)
yeah, the top-shelf synthetic gear lube doesn't come in 75W-90. well, maybe now...but...
Observations from changing Oil, Tranny, Transfer case, F&R Diffs demoncleaner 2nd Generation (2005+) 10 09-14-2006 06:35 PM
manual tranny oil drain plug location?? commutercar Archived Corolla threads 2 06-22-2005 01:28 AM
Change tranny oil for a 5 speed? izekat Tercel, Paseo, Starlet, and Sera Forum 1 06-03-2005 04:59 PM
1990 N/A Auto :( dave_id Supra Forum 6 08-26-2004 12:18 PM
A Camry with no Tranny oil change TaxiDriver Camry & Solara Lounge 18 05-18-2004 07:09 PM
