Paseo Daytime Running Lights?!?
I've recently got a 93 Paseo and when I put the key in the ignition and turn it, not only do the headlights come on, but so do the marker light, taillights and license plate light. Is this a normal function? I found the tail light relay and unplugged it. When I do that, only the headlights come on. Problem is, even if I turn the light switch on, with the relay unplugged I lose all maker and tail lights. It needs to be plugged in. Help?!?
(I've just done a 4efte swap and want to be sure I haven't screwed up the lighting system)
