problem shifting into 3rd gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2006, 11:23 PM   #1 (permalink)
View m97tercel's Photo Gallery
Question problem shifting into 3rd gear
I had an engine swap and everything else possible on my 97 tercel. during test runs I'm having problems shifting into 3rd and 5t gears, it's almost impossible to put into 3rd. i wonder if its because shifter cables are different length on the starlet and tercel. any ideas??
m97tercel is offline   Reply With Quote
Old 12-14-2006, 06:11 AM   #2 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
The shifter cables from your Tercel will work on any "E" series swap with no problem. I would check the syncros, especially if you swapped in a used tranny when you swapped your engine.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 12-14-2006, 01:12 PM   #3 (permalink)
i'm not sure suncro is the problem because there is no apperent grinding of the gears its just very tuff to get it into 3rd and 5th all other gears are fine
Old 12-14-2006, 05:37 PM   #4 (permalink)
Maybe its because of the LSD that i put in. I do not know? Please help i really want to drive my car NOW. Thanx
Old 12-14-2006, 05:41 PM   #5 (permalink)
Banned
4speedsleeper's Avatar
View 4speedsleeper's Photo Gallery
4th Generation
Did you put gear oil in your trany?It takes 75-90w or 80-90w about 4qts or just fill it till it starts to pour out the hole.
4speedsleeper is offline   Reply With Quote
Please Help Me With Gear Switching baller Archived Corolla threads 28 10-10-2006 01:45 AM
5 speed auto shifting 3rd 4th 5th astrotaco 2nd Generation (2005+) 7 06-23-2006 06:05 PM
Shifting into 1st gives me 3rd gear ?? xmacdaddy MR2 Forum 6 02-24-2006 12:42 PM
ATTENTION GEAR HEADS/MECHANICS: I need your help on my noise problem thisdj78 Camry & Solara Lounge 13 10-10-2003 03:38 PM
Problem shifting out of park!! DscCamry97 Camry & Solara Lounge 2 09-23-2002 12:39 PM
