Need Help With Thermostat - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2006, 02:39 PM   #1 (permalink)
View ndestree's Photo Gallery
Where is the thermostat located and how do you chage it step for step on a 1994 toyota paseo. Any help would be much appreciated. Thank you.
ndestree is offline   Reply With Quote
Old 12-14-2006, 05:14 PM   #2 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
It would take WAY too long to tell you step by step how to change it (that is what a repair manual is for), but if you follow the upper radiator hose back to the engine, you will see the housing under and behind the distributor. The thermostat is in the housing. Do a search on TercelOnline.com I believe I did a write up there telling you what other parts you would need to change it. It's not fun.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 12-14-2006, 05:36 PM   #3 (permalink)
Banned
4speedsleeper's Avatar
View 4speedsleeper's Photo Gallery
4th Generation
Okay, its on the right side of the block.But, it will be easiest to take the distributor out before you start just simply mark the dis and the valve cover so you can put it back in the same spot, or do it the hard way and fight with the dis in your way. Also when you put the thermostat in be careful not to over tighten the nuts or they will break.you can get replacement studs at most auto stores if you can pull them out.So be careful and have fun remember your car is old so the nuts and bolts arent as strong as they once were.Don't forget the RTV silicon its the blue stuff!
4speedsleeper is offline   Reply With Quote
Old 12-14-2006, 08:58 PM   #4 (permalink)
View Daox's Photo Gallery
I agree, it really helps to have a repair manual. Thankfully I just updated my site with the information you seek.
http://www.tercelreference.com/artic...placement.html
Daox is offline   Reply With Quote
Old 12-18-2006, 02:41 AM   #5 (permalink)
Wow, thank you, Your web site of how to change is, couldn't be for insightful. Tnaks BIg Thumbs Up!!!
Gen 3 I4 Radiator Change/ Thermostat Change RningOnFumes 3rd & 4th Generation (1992–1996 & 1997–2001) 54 10-22-2011 02:35 PM
thermostat problem wilmer Pre-88 Toyota Pickup/Hilux 6 10-01-2006 05:33 PM
Thermostat stuck shut? Purdue Camry & Solara Lounge 14 05-19-2006 10:29 AM
How to check your thermostat [56k overheats] Kidane General Discussion 9 01-07-2005 07:53 PM
THERMOSTAT - Please help! OBarbas Archived Corolla threads 5 03-09-2004 11:51 AM
