oil burning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2006, 08:42 AM   #1 (permalink)
View hamelpe's Photo Gallery
oil burning
I have a 94 tercel with 116k miles .I did the vss but still burn oil .I pulled the spark plugs and they were white no signs of oil. I don't have blue smoke in the am. I did a compression test 1-200,2-190,3-205,4-205. all looks good. I could use some advise as where / what to check next.
Thanks Paul
hamelpe is offline   Reply With Quote
Old 12-17-2006, 05:28 PM   #2 (permalink)
View NickR's Photo Gallery
Have you checked the cheap and simple thing: the PCV valve?
NickR is offline   Reply With Quote
Old 12-18-2006, 05:30 AM   #3 (permalink)
I replaced this when I did the vss
Old 12-18-2006, 02:01 PM   #4 (permalink)
Drives 1 loud yota!!!
View steveokinevo's Photo Gallery
in the morning i do get some smoke, and i think im burning a little oil too any suggestions???
steveokinevo is offline   Reply With Quote
Old 12-18-2006, 02:37 PM   #5 (permalink)
hamelpe: "vss" = "valve stem seals"? (Not vehicle speed sensor?). I don't know. It is always possible that the oil control rings are worn, even if the other piston rings are good (giving you that good compression). But I think this is rather unlikely, given your relatively low mileage, and very good (too good?) compression. Actually, those compression numbers ARE suspiciously high. Haynes gives the compression as 184 standard. If your 190-205 numbers check out, I would suspect some carbon build-up on the heads. I wonder if carbon could also be causing problems with the oil control rings? (Just a guess).
And, are you sure it's not leaking oil, rather than burning it? How much oil is it using, anyway?
Old 12-19-2006, 05:35 AM   #6 (permalink)
I use about a half a quart a week.
Old 12-19-2006, 05:58 AM   #7 (permalink)
View toyomoho's Photo Gallery
White smoke at cold engine startup is usually valve stem seals.
What mileage do you drive a week? This compression is pretty high, stuck oil control rings, worn guides, leaking oil someplace? Check the underside of the chassis for an oil trail. Might try something to remove any carbon deposits, if this engine has them. I would think if burning this much oil the O2 sensors and converter would start having problems.
Old 12-20-2006, 05:34 AM   #8 (permalink)
I put seafoam in the oil on Monday to clean the carbon off the oil rings .Will advise as to the results.
Old 12-23-2006, 01:49 AM   #9 (permalink)
91 DX
tyler88's Avatar
View tyler88's Photo Gallery
isnt white smoke is usually coolant burning...if there is coolant in your oil there is a much larger problem. blue smoke is oil burning.
Cheap, Fast, Reliable...Pick any two
tyler88 is offline   Reply With Quote
Old 12-25-2006, 04:41 AM   #10 (permalink)
Banned
4speedsleeper's Avatar
View 4speedsleeper's Photo Gallery
basicaly on a 3ee or any motor if you see white smoke its a bad water pump or thermostator blown head gasket really only a blown head gasket will cause the white smoke if its black smoke its you're rings.
4speedsleeper is offline   Reply With Quote
Old 12-28-2006, 11:28 AM   #11 (permalink)
z00y0rk28's Avatar
View z00y0rk28's Photo Gallery
ok, now i remember:
white (just white, with no shades of blue or black) = water/coolant
white/blue (looks liek a grey/blue color) = oil
black = running too rich
now we just need to find ways to make green and red smoke for the holidays...
Reppin www.torontopaseoclub.com all the way from the bay area
z00y0rk28 is offline   Reply With Quote
Old 12-29-2006, 06:16 PM   #12 (permalink)
91 DX
tyler88's Avatar
white coolant water burning smoke is not to be confused with a cold engine
2000 Corolla- Burning Oil :( miklebud Archived Corolla threads 12 10-08-2006 05:55 PM
Trading Taco for a moped big chris 2nd Generation (2005+) 126 04-22-2006 04:04 PM
93 Paseo burning oil djmixmode Tercel, Paseo, Starlet, and Sera Forum 14 12-24-2005 09:51 PM
1990 N/A Auto :( dave_id Supra Forum 6 08-26-2004 12:18 PM
burning oil silverstreakin Celica Forum 0 03-12-2004 03:09 PM
