92 Paseo Overheating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2007, 01:21 PM   #1 (permalink)
View fullcircle's Photo Gallery
Angry 92 Paseo Overheating
my 92 Paseo is overheating the shop replaced the the gaskets and the cracked radiator, the heat and fan worked the and the temperature was just fine. after a 15min drive from shot to my home it was over heating again. and no heat inside the car. after doing some research i THINK it may be the thermostat. if so where is it? can i replace it myself?
fullcircle is offline   Reply With Quote
Old 01-16-2007, 03:00 PM   #2 (permalink)
fhe
Speed Racer
View fhe's Photo Gallery
you can replace it yourself if you want...
not really to hard, get a chiltons manual to find out how....
its located almost directly under your distributor, but to the rear a little...
with a chiltons, its easy
fhe is offline   Reply With Quote
Old 01-16-2007, 06:41 PM   #3 (permalink)
View Daox's Photo Gallery
Its very easy to replace. Check out my site. There is a tutorial there.
Daox is offline   Reply With Quote
Old 01-17-2007, 01:03 PM   #4 (permalink)
thats right...FREE
Freebie Paseo's Avatar
View Freebie Paseo's Photo Gallery
I blew a fan belt last fall and it overheated after about 2 miles. Are you still getting heat?
it may be slow and ugly, but it was still free.
Freebie Paseo is offline   Reply With Quote
Old 01-17-2007, 01:30 PM   #5 (permalink)
nope, still no heat but the fan does come on. i'm going to take a look at the thermostat this evening
Old 01-17-2007, 03:04 PM   #6 (permalink)
solaraguy
anttarz's Avatar
View anttarz's Photo Gallery
i had this problem last winter, i temporarily disconnected the thermostat so it constantly flowed
2000 Camry LE
1999 Solara SLE V6 - Complete TRD Suspension (Struts, Springs, RSB, & FSTB) - OBX Headers, Random Tech w/ TRD Exhaust, 18x7.5 Kosei K1 TS
1995 Tercel Coupe -- 4-Speed, 15" BBS, ACT Clutch, CAI, Eibach Pro-Kit, FSTB, Custom Grill (sold 6/06)
anttarz is offline   Reply With Quote
Old 01-17-2007, 03:21 PM   #7 (permalink)
is that safe?
Old 01-17-2007, 05:27 PM   #8 (permalink)
91 DX
tyler88's Avatar
View tyler88's Photo Gallery
yeah for a little whole temporaily disconnecting the thermostat is ok i just keeps recirculating not allowing to get up to fll operating temp.
Cheap, Fast, Reliable...Pick any two
tyler88 is offline   Reply With Quote
Old 01-17-2007, 08:36 PM   #9 (permalink)
Your car will never warm up if you don't have a thermostat. So if its cold where you are... well, your going to freeze. For as cheap as a thermostat is I would sure hope you would just put a new one in.
Old 01-17-2007, 10:56 PM   #10 (permalink)
91 DX
tyler88's Avatar
yeah they are cheap and make sure to keep an eye on your temp gauge after incase you got a faulty one
Old 01-18-2007, 12:40 AM   #11 (permalink)
solaraguy
anttarz's Avatar
I didnt replace the thermostat cause it was in the middle of the week and i was on my way to class. It wasnt bad, the car just warmed up slower, still eventually got heat. If i remember correctly i never replaced it till the day i got rid of the car.
2000 Camry LE
Old 01-18-2007, 08:49 AM   #12 (permalink)
it's freezing in philly right now so i'm def. going to do it thr right way. thank you all for all of your help. i hope this fixes things.
Old 01-31-2007, 04:00 PM   #13 (permalink)
spridel's Avatar
View spridel's Photo Gallery
"92 Paseo is overheating the shop replaced the the gaskets and the cracked radiator, the heat and fan worked the and the temperature was just fine."
Its probably not the thermostat.
What gaskets were replaced? What about the radiator - where was it cracked? When they refilled the cooling system, did they bleed out the air in the system? No heat is a sign of low coolant. You're either leaking it out, or you have air in the system.
Did they pressure test the system after repairs to make sure it would hold?
Best case is they forgot to tighten a hose clamp or something...
spridel is offline   Reply With Quote
Old 01-31-2007, 08:18 PM   #14 (permalink)
View ndestree's Photo Gallery
if its a 92 and the thermostat hasnt been replaced yet, you might as well replace it anyways, i think i just bought min a 180 degrees f WAS 10 dollars and took maybe 45 min. to replace. also check the sensor that turns the fan on, is it turning on? you could also have air bubbles in the cooling system.
ndestree is offline   Reply With Quote
90 Tercel coupe 92 Paseo Interior? RANGER4219 Tercel, Paseo, Starlet, and Sera Forum 2 10-21-2006 10:11 AM
92 paseo srpings? MrPaseohead Tercel, Paseo, Starlet, and Sera Forum 7 05-21-2006 07:40 PM
Hello, 92 paseo here. MrPaseohead Tercel, Paseo, Starlet, and Sera Forum 15 11-18-2005 04:04 PM
Please help newbe !!!!! 92 camry V6 overheating vinniekhosla 3rd & 4th Generation (1992–1996 & 1997–2001) 1 07-06-2004 03:27 AM
