Stuttering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2007, 11:44 AM   #1 (permalink)
View sancho_153's Photo Gallery
Stuttering
ok so like i said in the last one i just got my car back from having a new enigne put in and im still working on the swaying thing, but now the question is why is my car stuttering...i put a new battery on because i thought the old one might be the problem. That obviously didnt solve the problem or i wouldnt b here. so when i start to drive it sputters unless i have the throttle in the right position...you guys know nething? Thanx
sancho_153 is offline   Reply With Quote
Old 01-25-2007, 05:42 PM   #2 (permalink)
z00y0rk28's Avatar
View z00y0rk28's Photo Gallery
is it a low idle? does it do this even when the engine is up to full operating temperature?
Reppin www.torontopaseoclub.com all the way from the bay area
z00y0rk28 is offline   Reply With Quote
Old 01-25-2007, 07:59 PM   #3 (permalink)
The idle is around 900rpms, and it still does it at full heat, but my radiator has a hole in it and needs to be replaced, Do you think that could be the problem?
Old 01-25-2007, 08:57 PM   #4 (permalink)
fhe
Speed Racer
View fhe's Photo Gallery
i would think its a clutch problem...
fhe is offline   Reply With Quote
Old 01-26-2007, 07:02 AM   #5 (permalink)
its a brand new clutch in the car so i hope thats not the porblem.
Old 01-26-2007, 02:45 PM   #6 (permalink)
z00y0rk28's Avatar
patch the radiator first, then see if it fixes the problem.
also, does the stutter vibrate the wheel, or is like a crackling noise that you hear towards the engine?
Old 01-26-2007, 03:39 PM   #7 (permalink)
the hole is pretty big so im just gonna get a new one but the stuttering is coming rom the engine.
Old 01-26-2007, 04:57 PM   #8 (permalink)
z00y0rk28's Avatar
i remember a previous car that the engine stuttered a bit from overheating... kinda like a crackling sound more so than a stutter. but as you can tell, it's hard to explain over a typed message
Old 01-26-2007, 08:52 PM   #9 (permalink)
91 DX
tyler88's Avatar
View tyler88's Photo Gallery
check your plugs maybe its a misfire if its all the way through the rpm range
Cheap, Fast, Reliable...Pick any two
tyler88 is offline   Reply With Quote
Old 01-26-2007, 08:57 PM   #10 (permalink)
fhe
Speed Racer
it could be clutch chatter.... dont rule that out is all im saying
Old 01-26-2007, 10:06 PM   #11 (permalink)
Drives 1 loud yota!!!
View steveokinevo's Photo Gallery
could possibly be the plugs, but i once had that problem and after replacing like half the engine it came out to be the fuel regulator. i would definatly check that cause mine sputtered too, and now its good so when u look at it(if u do) check for cracks, even take it off and look it over cause that was my problem. it was on the bottom and i never seen it, LOL
steveokinevo is offline   Reply With Quote
Engine stuttering at 75 mph Donald Tercel, Paseo, Starlet, and Sera Forum 20 10-10-2007 04:06 PM
stuttering and stalling with rough idle kurzawa Camry & Solara Lounge 0 08-20-2006 07:20 PM
Stuttering Start terrynham Camry & Solara Lounge 8 06-07-2005 07:28 PM
87 Camry stuttering and hesitating seanhist1 1st & 2nd Generation (1983–1986 & 1987-1991) 3 11-25-2004 02:52 PM
Stuttering Front Driver Window cobravap Camry & Solara Lounge 2 02-03-2004 05:10 PM
